French Style bulbs
  Clio 1,2 16V
The clio that im gona be getting has french style bulbs in the headlights low and high and fogs. im wondering whether to take them out because every Wednesday i go to my local police station to attend cadets any one have theyre opinions because i know there illegal and was thinking of just replacing them with 55k hids.????
McGherkin
McPension
You mean yellow bulbs? Get rid of them. Police magnets.
Only put the HIDs in if you have the correct housings for them or you'll burn everyone's eyes out. And I'm assuming you mean 55w. Be careful because the temperature created by 55w HIDs can melt housings. If in doubt, 35w. Don't go higher than 6k either or you'll look an idiot with your blue headlights.
By correct housings I mean these:
or
rather than these:
or
  Listerine & Poledo
Maybe for headlights but I've had Selective Yellow fogs for years and there's no issue with them... mind, I don't drive around using them like daytime running lamps like some do.
If you want to add an air of French to your fog lights, get some Lamin-X film in Selective Yellow.
As for headlamps, just get the best normal buls you can, HID's and other faux-xenons are MOT-failures
  Listerine & Poledo
Oh god. He said MOT fail. Watch the debate begin.
Yep, I went there.
Pretty sure it's true though, isn't it?
In any event, aftermarket kits will almost invariably end up giving brilliant visibility.......of the nearside ditch and motorway gantries.
McGherkin
McPension
isn't it?
Don't bait ;)
I'm talking about the main and dipped beams being yellow, fog lights are okay but chances are if a copper's pulled you over he will make a point of it. Yellow headlights will get you pulled over all the time at night.
  LY 172
Haha. My best mate did his MOT course a month ago in Exeter, and asked about HID kits. The reply was, if the car was fitted with washer jets as standard they need to work, if the car has self leveling it needs to work, if the beam pattern is correct and the bulb is of the correct type (eg H7.). Then it's all good for a pass.
The small print is that HID bulbs produce more Lumens than the legal limit. But this can't be tested. So it's an auto pass.
  LY 172
So, like my cup
It didn't have washers, or self leveling. Therefore they don't have to work.
WIN.
My only problem is my exhaust sounding "non standard"
