1987 Corvette C4 4+3
				Ive nearly finished the rebuild of my 172 which should hopefully be up and running Monday or Tuesday depending on parts arrival.
Today I got a battery on it to check all the electrics. After changing the fuse for the radio and horn to get them working I also found that I have no exterior lights (also had no lights before fuse change).
I have no sidelights, main beam, tail lights brake lights or number plate lights the dash and centre console also do not illuminate when I turn the lights on, nor does it display the blue symbol that shows if I have main beam on.
I have checked all relays above the passenger foot well by making sure they are all seated firmly. Whilst I was under there I found a disconnected black and yellow plug that I cant seem to find where it plugs into. Is this supposed to be like that?
I have no dipped beam bulbs installed as im waiting for new ones and my front bumper (front foglights) are also disconnected so I cannot check those lights. My rear foglights do work though. Alos i dont know if this is correct my radio is illuminated with the lights on or off.
