f7p-f7r conversion runing problems
Car  valver with mods! ;)
got my clio going agen on thursday nite, with the f7p head and f7r bottom end but i am having some teething problems. on light throttle it is going on to 3 cylinders, fine if your on anymore than half throttle or above 4000 rpm! i have changed just about every relevant thing for another out of my spares boxes, adjusted my ignition timming as much as i can even though these dizzys are supposed to be fixed and still exactly the same, i have plenty fuel pressue and all the other obvious things. anyone else whos dont one of these conversions had any problems?
Check the injectors and the connections to them. I've seen a few Mk1's which do similar things with dodgy wiring around the jet area.
Mick
Could well be mapping, what ECU is it running?
im runing the 1.8 ecu with a superchips chip, i am going to get it remmaped once motd, but not going to the tuners till i am sure this problem isnt somthing else! i am well aware that it os over fueling as it did the same with the f7p engine (cant leave it running in the garage for more than 2 mins before my eyes nip like f*** lol), sayin that when i remove the plugs from the current setup they indicate a nice clean burn...
What is the chip for mate? A 7P or 7R?
the chip is for the f7p, i know this is wrong but ive never seen this kind o running problem due to a map being wrong but hey theres i first for everything! just wonder if anyone had done the same setup and had similar problems
the f7p chip will run the f7r and its driveable (not recommended but it works)
checked your tps?
What Mick said, had a very similar issue on mine, dodgy connection on 1 of the injector plugs was the cause
was yours running fine up the revs yes? well checking out the wiring loom is my next option but its just that the f7p was running fine a few months ago!
Sort of yeah, it was a bit random though but the plug on 1 of the injectors wasn't fully plugged in so the connection was a bit dodgy. If it ran fine on the P then the chances are something hasn't been connected back up properly or a wire has broke or something like that, it has been known for the original wires on the loom to crumble & break
How have you attempted to do that?
You do realise that if you rotate the dizzy it will make NO difference to the ignition timing as the timing event is ECU controlled and based on the input signal from the crank sensor?
worked this out ^^^, dont know why i did it..... at the time i was wasnt thinking about anything other than gettin it running right! found the problem tonight tho... one of the pintle caps got damged when i removed the injectors to wash the head out a few weeks ago
