Brilliant, cheers!It's been a while since Iv done one on a sport but here goes
Remove offside wheel and arch liner
Remove front bumper
Remove offside headlight
Support engine
Remove engine mount
Use a 3/8 bit to turn the spring loaded tensioner to release belt tension
Undo 13mm pinch bolt on top of the alternator
Undo 16mm bolt from the bracket to engine
Remove upper tensioner spring bolt
Remove 16mm bolt from cambelt cover holding the big bracket on
Remove 13mm bolt from bracket
Remove 2 electrical connections from alternator
Remove main 16mm long bolt from bottom of alternator.
Remove alternator
I fecking hope not! Why so long?
I need to know if that ContiTech belt is alright first!
Replaced it now and it's still doing the same thing. We've tested all the earths and they are fine.
This leads me to believe it's either;
a dodgy replacement alternator
or
the thin wire that leads to it is corroded, so it's making the battery light come on as it thinks it's not getting charge so causing the alternator to not work. We stripped the wire back and it's still playing up though.
Has anyone any ideas, or other suggestions?
Cheers for all the help x
Haha should be good for another few years yet!Cracking...at least you got to the bottom of it...as I wont jump start your motor at CSS![]()
After not driving it for over 2 weeks... I've fallen in love with it all over again. Was gonna get rid but I'm glad I didn't. Trophy <3
