oreca group n exhaust
  172
Hi, im looking at getting a new oreca group n exhaust for my 172 as im unable to get a yozza which is what i would ideally like. Im just after some information, does anybody run these on road cars? If so does the noise quiten down when doing a motorway journey or do you get a whining droney noise? Any other info you can provide would be brilliant.
Brett
  172
Failing this im also now looking at the k-tec recessed supersport exhaust with a de-cat which seams would be more suitable
Scutch
  G87 M2, Megane R26
Loudest exhaust on the market are they not? It's basically a straight through system all the way.
  Sunflower Ph1 172
an exhaust can be loud on full chat, and quite when cruising like mine is. It was originally a powerflow with two silencers. After it fell apart (typically) I had the centre box removed and a straight tip welded instead of the original stealth tip. It's similar to the group-N in style now. It's very loud, but is much much quieter than the original that had a centre box when cruising (less boomy).
As said they are loud.
LewisTaylor has one (which is for sale i believe) and when i pulled up beside him on the motorway i could hear his exhaust over mine, bare in mind my cars noisy inside as stripped.
I really like the look/sound but they are far too loud for me to ever get one.
couldnt post some pics could you? As i thought about doing this with my stealth but not sure how it would look/work :)
  Sunflower Ph1 172
I've got a couple of photos, but none of the underneath. It's basically got a sports cat, then straight through to he backbox. Then just the same 2 1/4" straight cut pipe for the tip.
Please ignore the stupid cutout on the bumper in the first image.. Previous owner.
Day he exhaust was done..
They're too loud
Driving back from Wales on the motorway I ended up with ringing in my ears for 3 fecking days afterwards
Stupid exhausts and no idea how K-Tec say they're only 95db
My car is fully stripped but still
I've had a middle silencer fitted to mine which has dropped it to 92db and it's actually bearable now on long journeys - plus I can actually pass track day noise tests lol
95db idle?
Group N - 55mm Bore - Decat 63mm - dB Idle - 78DB - 4.5K RPM - 94Db
That's from there website - supposed to be 78db idle and 94db at 4.5K rpm
Which is critical because track tests are taken at 3/4 revs
In reality mine was 101db at 4.5k!
We also tested it inside the car when it was stripped out fully and it peaked on a drive at 105db - which was deafening
With the roll cage back in it was a bit quieter as I think it helped defuse the noise a bit - but I still couldn't drive it with the windows up without hearing protection :(
Scutch
  G87 M2, Megane R26
I don't think I could cope with that. My WR1 was bad enough. It used to shake the house.
Cheers for that! I may look into getting mine done as it will get the stealth boominess away from under the car I think :)
I know its got ITB's but this does show you how epic the noise of the oreca is!
  Sunflower Ph1 172
Mine is quite loud from the outside.. not sure if it's louder than an oreca.
  clio 172 cup
ive got a supersprint stealth system on my 172 cup and tbh its nice and quiet below 3k but abve 3k it just comes alive very raspy and loud and thats without decat mines going up for sale as i want a oreca one though
  Trafic 140dci
TBH K-tec's figures are right, mine was tested at 95.5db at 4.5k at Donnington. So think your baffles may need re-doing, as i drove to Nurburgring and back with no problems. Mine is only approx 3k miles old too.
I also past a test at Nurburgring for 95db at 3k (didn't say what i read) and 103db test at Snetterton (again didn't say what i read)
I also find between 2.5-3.5k it's very quiet (for what it is at least!) so is absolutly fine cruising at 70mph. Any faster and it does get loud...
I love mine and think it's a beautiful sounding exhaust, sadly now for sale, only due to having a 182 now!
http://www.ebay.co.uk/itm/190698616373?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
The Dark Knight
Really tempted to get one of these but thinking about fitting a 182 manifold, will the Oreca exhaust fit onto a 182 manifold or would I need an adaptor?
  Sunflower Ph1 172
I imagine it'd need chopping down, which will obviously effect resale, unless you sold it with the car, or sold it wiht he 182 mani.
The Dark Knight
Is it worthwhile fitting the 182 manifold to a 172? How much difference does it make? If theres not much difference I may just stick with the standard 172 manifold.
  Trafic 140dci
The whole lot here.
IMO opinion yes, but that's opening a can of worms on here....
