Hi All,
I'm new to all this.
I had the great idea of picking up a cheap 172 and then doing a few bits to get it roadworthy. The aim was to drive it around the roads until next summer and get used to the car and how it drives. Then work on it uprating things as I go along and then drive it around some track sessions next summer.
Well...
I decided to take a punt and bought a 172 with the triangle lights (I now know this is a phaze 2 but excuse my ignorance. I literally had no idea about 172's except for they were quick and the first breed of the Clio Sports (after Williams type).
Here is the car:
You may look at the pics and think... arr it looks like a sound car. Pump the tyre up and bobs your uncle.
Oh... so wrong!
The car has no Tax or MOT and has been left since 2009. On first inspection the Tyres were all completely slick... They have been driven well beyond their legal limit & the disks were completely shot. I decided to get it moved using a transporter.
Whilst getting it onto the transporter the guy ripped the front bumper off and smashed the front fog lamp. I was pretty annoyed at this and swiftly got a discount off the car.
I had the garage give the car an MOT as i knew this would flag everything i need to change to get it right. I knew about the tyres and brakes... but...
The garage phoned be a few days after dropping the car off and said. Mr **** the car has failed the MOT. I was like, ok so whats the damage. They replied with... 4 pages of MOT failures. Thats even before the advisories. The total failures was 36!
You may ask what it failed on... a few things I shall list.
Front Discs - £80
Front Pads - £18
Rear Discs with bearing and abs sensors - £300
Rear Pads - £26
4 Tyres (Went for Uniroyal Rainsport 2) - £420 with tracking and alignment
16 Wheel nuts as only 2 on each wheel - £28
CV joint boot kit - £14
Antirollbar bush kit - £5
All round Springs - £170 (Went for H&R 30mil drop)
Xenon Bulb - £80ish
Window Wipers - £30 (Went for Champion Contact Blades)
2 Tie Rod ends Outer - £30
2 Tie Rod ends Inner - £30
2 New reg plates - £25
+ more like seat belts, horn doesn't work, fluids, other bulbs etc
Things that were not a failure but needed changing
Bosch 4 year Battery - £63
Timing Belt - £50
Micro-V Belt as it was missing - £16
After this a full service needs doing with spark plugs, oil, fuel & pollen filters and an oil change.
There is more things left like a new drivers seat as the side airbag has gone off, new front bumper to find, new barrells to fit as they just spin.
So... the bill for parts so far (just the prices listed) - £1,385. The labour charge is about £400 for this too. So £1,785 just to get the car right. That doesn't include the price of the car!
The photo is of the car as it looks today when I visited the garage. I really hope to have it all sorted and back in the next few weeks.
I've never done a project like this before and if you had said i would do this a few weeks ago I would have said "Don't be stupid".
Many may read this and say... why didnt you just buy a car that was ok in the first place...
Well. The answer to that is the car is 10 years old and i knew things would gradually need to be replaced over a year or two so throught i could buy cheap and replace pretty much everything and get it done all together so there was a solid starting block. (I didn't want to have to replace everything all at once mind!)
I shall keep you all up to date with the progress. Once i get it back from the garage i shall continue to keep sorting bits. I hope to get some 16" Sportline Turini Alloys for next summer.
Well...
Here is the car:
Oh... so wrong!
Front Discs - £80
Front Pads - £18
Rear Pads - £26
Xenon Bulb - £80ish
Timing Belt - £50
