Went to work and back in it.
Absolutely hooned it about and realised that what I thought was instant power really wasn't,
the new solid engine and gearbox mounts DCIRaz and me fitted are amazing.
Hit the throttle and it now feels like you're getting fired out of a cannon,
minimal drive train movement really is the way forward. :evil:
Whats the vibration like? Feel much different in terms of acceleration?
Zero increase in vibration, the car judders a bit more on start up but that's it,
idle vibration is exactly the same as it was.
It's a small change in acceleration but it's noticeable mate,
the power delivery definitely feels more instant from not only a standing start,
but also when you drop a gear.
I was smiling my head off toady blasting it about, well worth it imo.
How much did it set you back for the solid mounts Dave? Sounds like a good mod to do
You'll need both the upper engine and upper gearbox mount,
if you just buy one then all the stress will be transferred to the other one.
Sweet f**k all.
It's not been washed since CSS. It's not been emptied out (still got a few detailing products in there from CSS).
It has done circa 1500 miles since.
It's gaining new rattles, knocks and the clutch feels terrible. Steering also feels wooly.
Really need to get my arse in gear and remove the rear shocks to see if they are knackered and if the helper spring is snapped as I really can't see.
Next month it's either clutch or getting the arch done. I think it'll be clutch first and foremost and then the arch can come another time.
Just took her out for a b-road blast, really went for it. Holy f**k do I love this thing. Off my tits on adrenalin.
This thing is just so f**king rapid, the only thing holding me back was the fact it was throwing me out the seat in corners (and I'm 17.5 bloody stone). Jesus christ.
^same. Today is wash day as well. I made the LY a bit grubby yesterday, think I'll do the RB too. They both need a good clean
£200quid from K-Tec, you'll more than likely find them cheaper in the for sale section,
but you may have a bit of a wait and you need to get in there first aswel.
http://www.k-tecracing.com/show_product.asp?id=2655&appid=2
Dave, Dave, Dave, don't say all this. These we're on my list of things. Then I downgraded to just the dogbone, as I didn't want things vibrate too much, but wanted the car to feel tighter. Now they're back on the list. Cheers.
(I was thinking this: http://www.k-tecracing.com/show_product.asp?id=3734&appid=2)
Doesn't sound too bad does it that.
Don't you fancy an aftermarket exhaust at all?
Yeah I do and will but money etc dictate otherwise.
Only had the centre box chopped out as it was split and kept blowing weld repairs out!
made up some window switches that fit into the handbrake cover ( not fully finished yet )
stops me cutting holes in my carbon door cards
Haha sorry mate, I don't know what people are on about with the vibration mines perfect,
plus me and DCIRaz fitted them, so you'd think with me being involved they'd be vibrating like f*ck.
But all i've got is instant power! :evil:
We're they hard to fit? Muchos temptation... Did you not do the dogbone one too?
Yeah i've got a poly dogbone aswel, but that was done last year.
They weren't that hard to change tbh, the hardest thing was finding a 16mm deep socket to fit the engine mount nut,
you'll need a trolly jack and a square of wood to put under the sump tank to support the engine,
then the same for the gearbox.
It's just nuts and bolts so it's quite easy really, it just took a whole afternoon to do it properly.
Changed the boot solenoid so the boot finally opens. Also changed both rear exhaust hangers so the exhaust sits very nicely now.
Been a busy boy today...
Fitted:
New grey Cup Turini's
JMS induction kit
And:
Cleaned throttle body
Removed and painted corroded engine lift points
Wire-brushed my drive-shafts and painted them
Replaced both broken ABS reluctor rings (brakes now don't judder at low speed!)
Cleaned, treated and undersealed exposed areas of the chassis (at some point the car has been jacked up in some -er- interesting places!)
Removed, cleaned and re-lubricated caliper sliders and gave the calipers a good going-over
Then went to Pirbright twisties for a spirited blast - What an epic little car.
Plans for next weekend:
Replace spark plugs
Perform an interim oil and filter change (Fuchs Titan Pro S/ Renault filter)
Paint inlets and cambelt cover in graphite HT enamel
Lol it makes me laugh how much people on here can do to their car!
I can take panels off and put them back as well as interior changes but anything under the bonnet or regarding brakes, and it all goes downhill or wrong lol I'll leave it to the professionals and stick to cleaning!
This.
I am a total and utter mechanical r****d.
Well I went round and touched up the paint on my alloy wheels where the previous owner had kerbed them. Fortunately only round the outer edge. Up close you can see it's a bit of a rough edge but at least it doesn't draw the eye to the damage. Cheaper than a refurb for now.
Then thought I'd stick this on the back window since I had it lying about! lol
Also gave both of our Twingo 133s a wash inside and out! Also fitted my replacement Stormforce cover on my Gordini....
I've just followed guides on here (after dealing with unscrupulous garages in the past, I developed an interest in how things work and I now find it pretty therapeutic to tinker with my own cars) and owned 2 172's so I've got to know them fairly well.
Been a very busy few days for me! Had the cambelt and aux belt changed at Ktec, as well as the brake fluid and new cat and back box fixings. I've also done a full service (oil, filter etc) and changed the rear shocks myself and had the wheels refurbed and four new Uniroyal Rainsports fitted this morning. Last on the list for this week is a new front Fabia splitter and some headlight correction. Well worth the time and expense though, the car feels and looks awesome and that should be it for a while :)
Hit the speed limiter rather hard and turned the EML light on. Woops. Have no idea what it might be? Car drives fine and CC still works...
Front bumper taken off and leaking headlamp washer repaired.:)
Tightened up all the seat mounting bolts in the hope the annoying rattle from the passenger seat might stop but no joy. Think the runners are just worn. :(
Oil change with Mobil 1
4 new tyres PS3's
Made a bracket to mount my fire extinguisher as its driving me nuts clonking around in the rear cup holder
Emailed Merlin Motorsport with some questions
