Fletch's 150k 172 Project..
Just caught up with this not been on here for a while. when you planning on getting a cage in?
Hi Rob hope you're well?
The next step is to get the car running again, and fit..
New cambelt/ aux belt
438 cams
Air con removal.
Then the roll cage. I keep on changing on what cage to get.
Tim popped over today to give me a hand fitting the aerocatches.
We first had a corona
[/url]
Untitled by fletcher10, on Flickr
one fitted..
[/url]
looks good need to see this car! Fancy helping me fit some to my pug ? lol
438 cams
Air con removal.
Oreca. let me know and i shall get Kennith to give you a quote
Fletch..... are they the flush fitting catches that are supposed to be secured under the bonnet? Hard to explain and i cant really see in the pic but i think they are.
Yea they will work ok same as mine.
Mine and Sams are flush on the top. Are your fixing holes lower than the actuall catch ? (creating a lip)
Iam about today if you need a hand mate ?
Did you bite that hole out? :p what you need is some hole saws and one of those multisaws..
438 cams
Air con removal.
Yeah am good, keeping busy. bought a ph1 last week so going to start attending some trackdays next year once its ready :)
sounds good to me, you thinking custom cages?
I thoubht you removed the aircon a while ago......
Ph1 nice one Rob. :) Keep me posted on what track days you'll be attending next year mate.
either a custom cages cage, or oreca race cage. And I still have aircon/CC. :o
Fletch, Aldi are doing one for 30quid from next thursday in all honesty it might be pisshh but I bought a 50quid corded one from builders merchants and that eats through anything i've tried so far might be worth a shot and once you have one I bet you'll use it on pretty much anything ;)
Thanks for the heads up mate. I'll have a look.
I had another go at tidying up the mess the dremel made of the bonnet :dapprove:with a 4" disc cutter it looks so much better. I'll get some updated pics up.
After having a quick go in Pete's ph1 172 on Wednesday made me realise how much I my little rattle box.
I am now temped to not bother with updated cams and just get the cambelt/ aux belt changed and air con delete and just get it back on the road.
Get Mike Woodford to do the cambelt and fit a set of 197 cams. That would be the best compromise as it seems a waste not doing the cams when you've got the perfect opportunity.
