182FF
Hi guys,
I've recently picked up a 182 FF and it is a great little car. There are a couple of issues with it that I'd appreciate some opinions on if you've got a minute. I've looked all over this forum and nothing seems to be solving it.
1 - Rattle
The rattle is a mettalicy and sounds like it is coming from the engine and only heard when the car is
A - partially warm up to fully warm
B - accelerating
C - 3000rpm upwards
Now I've climbed under the car and all the heat shields are where they should be. I can't find any locations where there appears to be contact on any of the exhaust (manifold included). I have moved the engine mount forwards 10mm, no difference. I have raised the engine 4mm (washers under mount) and no difference. If it was contact I would expect that to change it for better or worse. The dogbone looks to be in reasonable shape. The alternator bracket is tight as is the injector guard and the ECU bracket isn't broken.
So my current thoughts are that it could be a belt pulley bearing or even knocking.... if anyone is wondering what I class as mettalicy then here is a recording. I hope the sound can be heard, it isn't very loud.
https://dl.dropbox.com/u/15177330/Hosted/My recording #5.wav
Any suggestions?
2- Oil leak
Another problem I believe is common. This one has been around since the cambelt was done three years and 36k miles ago. The two MOTs since give oil leak as an advisory. The leak is somewhere under the cambelt cover, not huge amounts of oil but over three years it has got all over the place. I cleaned up under the engine mount bracket but looking today, 300 miles later, there is a fair amount of oil under there again. The belt was done by Nationwide Autocentre Letchworth... reputable?
Why would a cambelt change trigger an oil leak? I can't seem to find the camseals to buy online, and how tough would it be to change them if I was to do the belts?
I am thinking I might just do the belts and see where the oil is coming from at the same time. Or since I'm living near Warwick I might give Fred from Birmingham a call. I'm worried what the oil will have done to the belts, they are both covered in the stuff.
Thanks in advance guys. Once I get to know my car properly I'll be in a position to offer advice rather than just seek it!
1 - Rattle
B - accelerating
C - 3000rpm upwards
Any suggestions?
2- Oil leak
