Those who know VAG
Does anyone know what bits I need and where I can get them from to convert my 02m 6spees vag gearbox from a hydraulically activated clutch to a cable mechanism?
Starring to think its the only way forward with my car at the moment
Because I'm having trouble retrofitting a hydraulic system to my car. It seems an easier task to modify the box to accept a cable
You would have to cut a whole in the bell housing, there's nothing for the fork to rest on inside and no bracket on the bell housing to hold the cable there. It will be less hassle to retrofit a hydraulic system and imo better overall anyway.
Asking for trouble then. Lots of things to go wrong
Your options realistically are:
Swap down to the box you can easily cable convert
Remote the master cylinder
Replace your pedals with a pedal box
Converting your box is going to be WAY more hassle than any of the above.
It was an option if the box could be converted. I have a master cylinder in the bulkhead but no means of attaching it to the pedal properly
