Cracked screen after trying to fix water leak..
  Renault Clio 182
Hi,
After attempting to remove my window wipers to try see if the drainage holes are blocked I managed to smash my window after following a picture on here of someone trying to lever them off.
Does anyone know how much around about the window will cost to replace on a 182 as I don't have windscreen cover.
Thanks
Alastair.
  986'S 172ph1+182FF
LOL, sorry. I had a screen fitted on my old 306 for £50 cash, would imagine a 182 will be £150+
  Titanium 182
I did this on my last car, rang insurance added w-screen cover then claimed 3 weeks later.
Don't cry at me, couldn't care less.
Sheila’s’ Wheels’
  Whichever has fuel
You have to be a bit of a special breed to try and lever something against a sheet of glass.
What exactly were you expecting to happen? ?
Sheila’s’ Wheels’
  Whichever has fuel
  Clio 1.2 16V
Had mine replaced on the 1.2 for 170 (rain sensor too) ring around local windscreen fitters. Autoglass wanted 400 and that was with "discount" lol...
  Titanium 182
To be fair when I cracked mine, it pressed on the scuttle panel near the bottom. The screens go down under the top of the scuttle a lot further than you'd think.
  Renault Clio 182
Exactly right, I didn't realise the windscreen went down that far under the scuttle panel. Well thats a mistake I won't be making again lol
MarcB
  182 Trophy & 197 F1
Screen without rain sensor in pale blue =
Screen "with" rain sensor in pale blue =
There is also fitting kit & Seal kit that are listed for the windscreens as well as a regulating block thats needed.
  28k Trophy - R1200GS
Pick up a screen at the local scrap yard?
Then get someone to remove it and put it in your car?
Cost me £20 for the windscreen and then £50 to remove and fit. Jobs a good one.
  Mk4 Mondeo Estate
Sorry but I cant help but laugh at you using a bar on your windscreen. Use a puller tool to pull the wipers off of the shaft.
