Had a productive day with the ph1 today, tested the alternator to find out that it was broken so took the alternator off (and everything else in the way!) and took the opportunity to fit the RS stamped inlets that have been sat in my shed for the last year. Now to source a replacement alternator and put it all back together.
been polishing the crazed and pitted 182's headlights. by hand, took ages, 1200wet & dry, then 1500, then 2000, then some halfords cutting compound, very good results in daylight but when the lights are on in the dark you can still see some imperfections, needs 2500 grit then another good polish.
also had a seal for 2 years and never knew where it went... found out today , engine bay / bonnet front seal. back in place finally.
Not checked the oil for 6 months and it was dead between min and max, so topped it up with 0.5l.
Also washed the car.
got a new bumper and had it sprayed today too, so fitting tomorrow hopefully. if a new headlight washer arrives (leaking b*****d)
Went to renault and bought the correct down pipe to CAT fitting kit and then the o-ring clamp at the other end.
Then called Dan at 519Automotive to find out what silicone seal he used from ECP to seal it up ?
ECU reset (as it learnt my driving style while it had a popped off pipe), Mirror bulb replacement and an Oil Change on her Fiesta ZS.
Gave it a good clean an polish inside an out an check the essentials under the bonnet an had a good scout around ready for our trip up to middlesborough on christmas day
Fitted new plates , washed outside , dressed tyres, ,interior cleaned and new matts all round. It was my Titaniums first wash, tried the turtlewax liquid gold - wont be using that again.
Removed a tesco bag of crap from the car!
Driving to Laaandannn taaaaaan tomorrow to pick up some mates
Pulled the door apart on the dci to fix the window that decided to fall apart yesterday on the motorway in the rain
Cleaned:
It's been lovely and warm today, so washed the 200 with a t-shirt on. Summer is on it's way!
Live to fight another day. I was conscious of mine but touching wood (not that type as it would be odd) they have been fine.
I think so! It is very loud, but its okay. If I could have tried it first I don't know if I would have bought it but will stick with it.
Tried to fit my carbon bonnet bonnet must of moved while i was marking the holes out so now have a cheese grater slam panel ffs. Also but the exhaust back in its correct position as it was rubbing on the bumper
Oil , filter and sump plug washer change using the recommended Elf Evolution.
Weirdly they only sold it in 1ltr bottles at 6.50 +vat a pop, ended up getting a little discount and so £33 for 5 ltrs. Next time if I don't try another brand I will try and get it online.
Oh and also did a oil, filter , plugs change on the father inlaws matiz . Both in this rain :)
Fitted a new rear number plate light & applied a new 2.0 L 16v oil cap sticker as my previous one had started to bubble, not bad for over two years on there & replaced my air box bolts with fresh new ones from pro-bolt.
super exhaust bodge to be proud of :)
Yesturday afternoon I noticed my exhaust sounded like it was blowing and at closer inspection it had a huge hole in the side at the hanger. So with no one in the area with a backbox forsale !
I grabbed a grinder and an old exhaust from my rover and ended up making a stealthy rude boy exhaust that should last me!!
Check out the pics 》》
Chopped the end off
You have to get down low to see it, bit loud tho
^^^ Massive bodge, nice one lol! Watch it doesn't melt your bumper.
Mine today was replacing my smashed Cup splitter with a Skoda one (Pinched off my Bro... Cheers!). Gutted that it broke, but couldn't live with it chinless so a Skoda one it was.
