Need to run front spacers due to running wider tires and having camber
Car  03 clio sport asc
Hey Guys
I know this has been asked a million times but want some personal advice, I'm running standard Australian spec 15x7" Clio 172 wheels on my cup which were fine with the current 2.5 degree's of front camber when I had 195 / 50 / 15 tires but have since upgraded to 205 / 50 / 15 tires and the front do not fit, looks like I need to run atleast a 10mm spacer, I am thinking 15 - 20mm will be better as I want to run a bit more camber shortly.
Best spacers to use and where to buy?
Is there an issue increasing the front track and leaving the rear standard?
This car does get tracked quite often therefore quality and safety is very important to me.
David
H&r spacers ive got are 25mm and brilliant. Those or eibach id go for. Maybe widen the back 15mm too?
Just got some Sparco 20mm hubcentric spacers for the front..will I have a issue if i only run front spacers?
