clio mk1 f4r hybrid project
  clio 197
i am starting my project thread again as the last one was terrible lol
i bought the shell off of a mate who thought it was a good idea to take out a perfectly good f7p engine and replace it with the worlds most unreliable 1.4 gtt engine,
after running out of money and enthusiasm he decided to sell it to me with full willy interior, for 300 notes
i started by completley stripping the exterior and removing and treating all rust, behind the front wings was quite bad but all have been welded up and primed to stop any water ingress.
  182/RS2/ Turbo/Mk1
Glad to see a proper project thread starting for this, it looks like a great car from the pictures in your last attempt :)
  clio 197
526138_10152265374300007_1447097181_n.jpg18313_10152265374130007_1978255004_n.jpg522169_10152265374000007_644998609_n.jpg
when i jacked it up and the jack disapeered into the cill i realised it may be a bit rotten
so while i was away the elfs went to work on the cill thanks to jamesb so when i retured to the unit the cill had been repaired welded and undersealed, as had the big hole in the boot.
  clio 197
donor car arives, first i must appologise to ph1 enthusiasts and that includes myself, this car i bought off the brother in law for £750 full mot and tax perfectly good car but was to exited about getting on with the hybrid so i started to strip down this lovely car with brand new belts and clutch :nono:
  clio 197
the trial fitting was goin well and i had the engine out and at 12oclock at night we decided to see if it was going to fit,
getting carried away i tried putting it in with all the aircon and alternator still on which is not recomended .
after removing all this while the engine was in the air it bolted straight in with no modifications apart from gearbox mount (thanks to dannyr for this information)
  clio 197
engine was back out for cleaning and painting which is not my favorite past time,
so after a full nights work the engine was finally ready for final fitting and the dreaded wireing
  clio 197
bad image i no but you get the idea this was the 5th night of work and the easy bit was done engine was all in mounts all on,
and found a brand new polyflex dogmound on the donor which was a bonus....... wireing time!!
  clio 197
well i took a step back and let my good friend mark butterworth founder of the ctd club in suffolk take over on the wireing,
all the wireing was done in one nights work, i used 172 dash clocks and engine ecu, wired into the original valver car loom. unlocked 172 ecu and emulator chip.
after wireing was complete it wouldnt start, we tested all the solder joints, leads all were sparking and couldnt understand why it wouldnt fire, until the father in law came down to the unit one day and suggested a sollution to this problem............................................F.U.E.L
yes i forgot about an important aspect of the internal combustion engine, it had no fuel,
after getting over this brain teaser of a problem it fired first time!
  clio 197
thanks to dannyr a friend of mine and a well known member on here i got hold of a pair of matched inlet manifolds,
after a quick clean and a lick of gloss black they were ready to go on
engine bay was pretty much complete and just needed a cup alternator set up and alternator
ktec ph1 172 decat arrived, so with a little hard work i had to drop the subframe and take most of the skin of my hands to fit this but it works!!!
  clio 197
so after a masive ebay session i had replaced
bottom arms
ball joints
driveshafts
track rod ends
front wheel bearings
discs and ferodo 2500 pads
rear discs bearings and pads
apex shocks and springs on front
apex shocks on rear
anti roll bar links
  clio 197
wheels arived, a rare find on ebay, these wheels were in good condition but good it not good enough for me,
they cost me a mere £160 with center caps
so as they had a decent paint job on them.... i sent them to the shot blaster lol
underneath the paint they were mint no dents cracks or repairs.
as we speak they are being painted by the brother in law but will not fit these untill last thing after the car has been painted
  clio 197
as im on hold over xmas and in the filling and sanding stage of the shell, plus dannyr is rubbing his gleaming new ph2 in my face, i thought id take delivery of a new daily sensible driver lol
so as with all dailys you just have to leave them standard.....
and then i was left home alone with my computer......
oops... yes so i spent a small bit on the standard daily
and yes i no ktec coilovers are not great but this is car is not meant to be a performance track car
Yosemite Sam
  Whichever has fuel
You should have just bought my project off me.
No rust, fully caged, no iffy repairs on the sills and all hard work done.
  clio 197
Exhaust was done yesterday full power flow custom system with 172 decat, 57mm all the way through with Center silencer and back box with 21/2 inch rolled tip,
Fairly loud may have to add something else when it's road worthy but it will do for now,
  renault clio 172
I am new to the forum after buying myself a Mk1 clio 1.8 16v which has had the 172 conversion done.
I intend on doing trackdays with it and the first one being booked for 16th feb at oulton.
Since purchasing, i have had the cambelt and tensioners done along with the dephaser...(not cheap) and all seems well until i was driving it the other night and the aux belt came off which runs the alternator and water pump. This made the car overheat and battery die all at the same time. (the joys..lol)
This happened apparently because the power steering pump has been removed so the engine would fit therefore leaving the aux belt without enough tension or enough tensioners.
Do you have any experience of this and if so what was there solution to it???
Any help would be much appreciated.
Thanks.
Darren
  renault clio 172
sorry about all the questions...lol...i have a mk1 clio with 172 conversion that i recently brought and my aux belt came off due to the power steering pump being removed which gave the belt extra tension. Looking for a solution now if possible.
  renault clio 172
  clio 197
I run a cup set up clio 172 cup alternator brackets and alternator, I use a manual tensioner with a 850mm belt so no need for aux spring tentsioner, simple and works well
  clio 197
So all painted today after along wait tomorrow will be flatting and polishing by s.w detailing a local detailed in suffolk that provides an a* serviceImageUploadedByTapatalk1368899370.677555.jpgImageUploadedByTapatalk1368899389.034836.jpg
