Dr HMS Derv Destroyer
MK1DCi/vivaro/REN’11
been told by a renault diesel mechanic. he said it sounds like a bag of f**king bolts. tapping/knocking away and the noise not clearing as the revs go higher.
he was the original guy that did the leak of test to find out my old injectors are fucked. it drank fuel on those like no tommorow so i can only presume on what he has said of ' bore wash ' from an overfuelling injector/'s
current milage on this is 105,800 if that helps.
i cant see pistons rings failing that early on a diesel surely!
getting andy to do a full compression test tommrow as something is bad, really bad.
worst case, new second hand engine.
this one has had a head change but that willnot make a difference as its ran with it for 7k miles
