Removing sump for ARP rod bolts
Trainerbrow
  Mk1 Audi TT 3.2 V6
Can this be done easily? Anything else need to come off bar the bolts for the sump?
And I assume it's sealant to put back on, no gasket?
  Mec 350 slk manual
May have got it wrong ? But it was a bit more than just whipping the sump off and plastic tray ?
Chris205
  Many Things
What are the benefits of upgrading the rod bolts, is this the weak part on the bottom end or is it the rods themselves?
  HBT 172 Cup
As I said dan got it wrong , but we did find a lump of sealant floating around in sump ? That was worrying
Standard from the factory. Ive pulled apart a couple of untouched factory F4R's both had a shocking amount of beige silicon in the pickup (the standard sealant used by renault on the main cap). tut tut renault.
  Mec 350 slk manual
That's right it was beige , the oil light on and the oil level was correct, so had the engine flushed new oil and filter light went out may have been that .
