Hi, i really need some help or advice
Recently the clio picked up a weird wobble from the front left end which felt like loose wheel bolts after checking everything, i couldn't find anything which could cause it other than a damaged cv.. i replaced the driveshaft and the wobble persisted, i have also replaced a hub and checked every possible thing i could think of, i have tried different wheels, checked the discs ball joints and engine mounts, checked for play but i can't find anything obvious.
I noticed the wobble was only under load, if i put the clutch in and coast the wobble goes away, this lead me to believe it could be my diff or gearbox, i consulted a local garage and mechanic who lives nearby and they both agreed, after sourcing a new gearbox with 30k miles on it, i had it replaced but the wobble remains, both the garage and the mechanic have no idea what it is, the garage suggested i tried replacing the other off side drive shaft how ever i suspect this wont solve the problem as there are no obvious problems with it..
its starting to get slightly frustrating now as im throwing money at the car trying to get it fixed and nothing so far has worked and no one has manaed to pinpoint the problem so far, im not sure what to look for next and have no idea how to solve this issue.. any help would be much appreciated.
