Chip ill take it
what did urs cost to put together and who did you entrust to do the work?
Mine was the MWM demo car originally, so I re-used the external parts to the engine for turbo and manifold etc and ECU, effectively thats about 3 and a bit I reckon if buying new, as closest you will get is the ED kit plus an aftermarket ECU and mine is on some 197 bits too which cost about 400 ish secondhand (head/cams/inlet)
Then the rebuild costs were approx (I dont keep receipts, lol)
Engine cylinder head rebuild:
parts : 500
labour : 0
Work done by Lesley Collis
Engine bottom end build and engine build up to mate head to bottom end with belts and gaskets etc :
parts : 2000
labour : 1 pizza hut and 2 harvesters
Work done by : Chip and Dan@SJM (formerly known as Danlp6 on here)
Gearbox rebuild with Quaiffe diff:
Parts : 1000
Labour (and rebuild parts) + transport : 400
Gear oil : 60 ish
Work done by: agency transmissions
Clutch
Parts : 500
Labour : zero
Mapping
Rolling road rental for half an hour : 25
Labour : zero
Fuel mapping on the road and on the rollers and to and from the rollers : 100
Work done by : Chip, with assistance from Lesley Collis
Then a couple of hundred in oils and filters and fluids for build and running in etc
So around the sort of 7K ish mark, although if you were paying labour you would probably be nearer the 10K mark all in.
