This is a copy of a post from my turbo thread, but I thought it might be interesting to see what other people have done as well now that turbo cars are starting to become more common and hence more people likely to need bigger brakes.
I know Porkie has wilwood calipers on his, and James has got some pretty decent 4 pots, what have other people got and what do they think of it?
My work in progress post about mine:
Hoping that it works really well, and the good thing is that although the tarox 6 pot calipers are a load of money the pads and disks themselves that I have used are actually pretty cheap so when they need replacing it will cost me less than a set of HC disks and DS2500 pads does for the mrs RS2 clio, well under 200 quid all in
The pad size is huge, I will have to try and get a picture of one of the new pads compared to one of the old ones to show just how much more contact there is, and hence how I can get away hopefully with running a more "fast road" type pad than needing a race one which should mean they last longer.
Well Ive made some decent progress towards getting my big brake conversion onto the car, and ive also fitted some KW Variant 2 front coilovers.
The calipers went off to a friend who is a prototype brakes engineer for goodrich who normally works on WRC cars and the like so probably seemed a bit old school technology to him, lol.
He kindly rebuilt them for me, including cleaning up and regreasing all the pistons, cleaning up the threads and fitting new brake nipples and making some new balance pipes.
Need to give them back to him with one of the old lines so he can make me some new brake pipes and also I need one of the nipple threads helicoiling as one of them didnt clean up well enough just from running a tap down it, hopefully going to get that done later this week but am in the queue behind Msport at the moment so cant really complain too much about the timescales seeing as he's being doing it all
free of charge for me as a thanks for some mapping work I did on his competition pulsar a few years ago, its nice when people remember and payback favours.
Grabbed them back off him again for the week so me and my dad could finish handmaking the adaptor brackets to fit them to my clio turbo, using some drilled and grooved 300mm disks to replace the original 280mm (iirc) ones.
Excuse the fact the pictures show the pass side caliper on the drivers side, was just a case of only had the pass one caliper to hand at the time I was doing that bit as dad was using the other one while finishing off the second bracket and the wheel I had off was the drivers one. They are identical other than the balance pipe and bleed nipples are fitted the other way though so it makes no difference which one goes which side, you can set them up either way just by swapping the bits over, and likewise I know the spacer only had 3 bolts in, was only mocking up, none of these are finished pictures, will hopefully get those later in the week if I get a chance to do some more work on it, although got so many cars to map this week its actually looking like I might end up having to just whack the old brakes back on for combe perhaps.
Coilover and disk bolted up:
Caliper fitted under the wheel to check for clearance:
Closer shots showing just how close it is:
Might need to go for very slightly bigger spacers to get a little more clearance but will see how I get on with it first.
