If you space the wheel out a lot and only use a 280mm disk you should be ok.
Is there any issue to the brake pedal with the use of oem brake discs (or other) with 24mm width combined with the clio's 197 brembos?
I mean that if there is any gap in the pedal once the disc (24mm) is thinner than the 197's disc.
(sorry for my English)
Its very specific to the wheel, you will just have to try it and see.
Does anyone know where I can buy adapters to fit clio 3 brembo calipers into ph1 hubs and 280mm stock disks ?
