Cambelt Con/Rip off tactics (If you fancy a laugh)
Status
Not open for further replies.
Car  Renault clio 2005
Disclaimer.
The following member seems to be suffering from a severe case of "Gullible-itis".
Please take the below with a pinch of salt and rest assured that Cliosport as whole, and it's traders do not support the below statements.
The correct timing for cambelt changes are mentioned across this site, so please use those, but feel free to use this for your general entertainment.
If you want any detailed information about what servicing is required on your car, feel free to contact any of our specialist traders, including BTM Performance, 519 Automotive, SJM, Diamond Motors and Birchdown.
Have recently been speaking to a manager from a Renault dealership And he has told me the truth about the cambelt change on a clio ph2. He has basically confirmed that a clio will not need a cambelt change until 75k regardless of age. He has said some of the best cambelts that have been seen are on low mileage cars that are 9 years old. Age has no impact on cambelt life. Cambelt life depends on the forces that are put through the belt when accelerating hard. the harder you accelerate at the peak torque of the engine the quicker the cambelt will show signs of fatigue. and is possible to fail. but he has never seen a correctly clio cam belt fail even when on 100k. So I would advise people to ignore this age issue people state on cambelt. we both think this is a money making tactic based on incorrect fears on cambelt failure. and unrealistic cost on cambelt damage repair.
Re: Cambelt Con/Rip off tactics.
Haha!
I'm a half wit with cars and even I know thats a load of b****cks.
Hahah!
Oh dear. It's common knowledge that rubber deteriorates!
Yes very True Rubber also gets harder with age. and This belt is in a very contained Environment not exposed to the normal issues rubber is.
Isn't the age related to the heat cycles of the engine. Belts gets hot and cold so goes brittle. Hence why age is a factor ?
​What happens when your tensioner fails? Toes the belt keep running on air?
When I had the belts on my 172 done when i bought there was cracking all over the place! That was a 7 year old belt with 90k on it. It wouldn't have lasted any longer.
Isn't the age related to the heat cycles of the engine. Belts gets hot and cold so goes brittle. Hence why age is a factor ?[/QUOTE
yes That is very true. However heat cycles only reach full potential on a higher mileage. Age is just a number.
I mean, I guess those rubber tyres that start cracking when old must not be made of rubber. As it wouldn't deteriorate. Nor would those rubber bushes that deteriorate with time. Or those rubber brake hoses. Or easiest of all, wiped blades never go hard and stop working. It's all a myth.
Capitalism at work. Brainwashing people into buying stuff they don't need ;)
exactly mate that is a higher mileage than reccomended belts should be changed by 75k even if that comes in 1 year or 20.
7 Years and 46,000 miles.
Still believe they don't deteriorate?
If you leave a rubber band lying around for a month or two, it becomes brittle regardless of whether you've been repeatedly stretching it or not.
Your belt is essentially a fcuking great rubber band.
72k, not 75k. So when my belt snaps are you or that t**t at Renault willing to buy me a new engine???
​If you believe this or he thinks this is true then this should not be a problem.
Yes. A Poorly maintained car will show this. A well maintained car won`t. My mate has been a regional manager for Renault for years he has seen it all. he says that if a clio is maintained well and the cambelt is changed by 75k there is no worry`s with camblelt failure :)
Flol. Do tell me how a poorly maintained car will have an effect on cambelt life.
Because a well maintained one would have had the cambelf changed on time.
Poetic brilliance would be in a few years time, mr chaz puts up a "my Campbell snapped" thread.
i honestly couldn't contain my exitement
To give you an idea of why you shouldn't trust the managers opinion in this case then read this. I was once in a Renault main dealer bodyshop when the experienced body shop manager walked by, stopped and asked me where I'd bought my bodykit from as he'd never seen it before. 100% standard. Working at a dealership doesn't automatically make you correct I'm afraid.
72k, not 75k. So when my belt snaps are you or that tw*t at Renault willing to buy me a new engine???
if I worked at Renault I would be more than willing to give you a new engine of your choice. I know the truth that it is all related to mileage and not year. also depends on the model in question.
Wanker, its 72k so that's b****cks for a start. Most Renault dealers don't even know the correct way to replace a cam belt on a Clio.
ahhhh bloomin eck... i knew i shouldve bought that rs that was on 80k without the belt change for 300 quid less. what a waste of time the belt receipts i have are now! damn you all knowing 'renault manager'... damn you to hell....
Good Man will post it if it ever happens lol.
And that's your problem chap, you don't know what you talking about.
You have come in here talking crap from a so called manger from a Renault main dealer, as the saying goes "a little knowledge is a dangerous thing"
I take it you don't even own a Sport?
Charles 29 Dorset Driving Instructor. Passionate about Renaults First car was renault 5 Now have 2005 clio 1.4 16 valve dynamique
And that my friend sums you up...
Apparently the whole depaser thing is a load of b*llocks too,
when they're worn in properly they're meant to sound like a knackered old black cab.
Haha Haha this thread cracks me up. Its not like my sub 50k Clio had a badly cracked cam belt or anything...
Status
