Juddering
  Renault clio 172
Hi I have just brought a clio 172 and when the revs are below 2000 and you put your foot down it judders for a bit then the power kicks in, any idea why this is happening.
​thanks
  Renault clio 172
Thanks for the reply I have changed the plugs to the correct ones and the coil pack looks new, do you think it could be the fuel injectors?
Dicky Belly 2
  Mk1 Audi TT 3.2 V6
Doubt it unless your management light it on.
Does it sound knocky? like a diesel?
I assume that this is just under load and not sat revving?
Dicky Belly 2
  Mk1 Audi TT 3.2 V6
Chris, I paid £1000 for it, code reader found nothing
I think the loud knocking noise would suggest that a code reader would be as much use as a chocolate fireguard.
I assume you didn't research these cars before buying?
Well, if you want to change the depahser, you need to do the full cambelt kit too. You're looking around £650 all in with one of the specialists on here.
Or, what you will probably do, is take it to your mate Dave's garage, who will charge you £300 because "it's all bullshit, you dont need the right tools", and they will f**k it up royally. Timing out etc. Your choice.
  Renault clio 172
Cheers mate I did some reaserch before buying one the knocking noise stared a week after I got it plus I thought it would be ok cos it had all the works done at 70000 and its only on 90000 now
