Urgent need help with stalling issue
Car  1.2 16v clio
so today a barely made it home alive thanks to this stupid car
the car keeps on stalling and when i touch the revs it will bog down and stall out once i try to start the revs will instantly drop back down
this problem kept on happening every so often at the worst places on the busiest roads
the throttle body has been cleaned a month or 2 ago
the crank shaft sensor has been cleaned aswell
does anyone know what this might be
if it helps its a 04 1.2 clio d4f engine that gets serviced regular without fail
Coilpack, injector or HO2 sensor is my guess but ideally it needs plugging in
no its the ph2 2004 but i believe they have the same engine
ph2 or ph3? I know the early ph2's had issues with the ecu wires rubbing through but this was fixed on the later ones.
Does it look like this?
Or this?
Or this?
might sound stupid but aren't they the same lol
its that shape and headlights my car is more like the top one but 3 door
learn something new every day lol defo the top one same bumper and wheels haha i can't believe i never noticed that
My 1.2 8v used to do something similar to this; you could be driving along, dip the clutch to change down at a round about of something and the revs would just drop off to nothing. Used to bump start it with mu continued momentum as I had a decat. I tired changing the coilpack etc but none of it helped. If I remember correctly, it was something to do with the MAF sensor; if I pulled the pipe going to he sensor off the engine would not stall. It just went away by itself to end up with :s
my car is 16v and i think the throttle body etc is different on them cars since my car is meant to be at a garage either tomorrow or friday having a wheel bearing done i will see if i can get a diagnostic test there aswell
so car went in for a wheel bearing today also the mechanic put it on the computer to find no faults afer he spoke to another mechanic that knows more about renaults he said to change the crank shaft sensor as he said it gets hot then fails so i bought a new one hopefully i wont have the stalling out problem
