Help clio mk2 stereo
  Clio 1.4 16v k2 2000
Hi guys I'm new here and this is my first post, I brought a clio mk2 w reg a month ago with no stereo. I brought a second hand one from eBay model number 8200 483 751. When I connect the stereo there's no display next to temp and clock so j can't enter code :( is this the rigt mobel stereo for the year of car?
LB197
Hi, make sure the small square cable/s or the red if its there, are in properly as that's the cable to the screen, other than that it may have come out of the clock, but that's a dashboard off job which is really easy and there's a guide on here for taking it off.
Although to enter the code, on the front of the radio numbers 1,2,3,4 are the code sequences so for instance if your code is 4321 press 1 four times, 2 three times etc.
Thanks LB-1 will give it ago tomorrow and post back. i forgot to say when the stereo is connected if i press the power button and wait 2 seconds and press eject i hear a loud beep from the speakers. will check the cables at the back of the display. i have time and outside temp. just no stereo display so i can enter code.
kind regards
LB197
kind regards
that beep when you push a button is just the radio telling you that you need to put the code in, thanks
Still no joy with the stereo. Does anyone know if the model stereo will work on a mk2 clio w reg. it's a renault 8200 stereo :(
danward
  M135i
Don't quote me on this as it's a wild guess, but 8200 may well refer to the software version. If it does, I don't think yours will be 8200, as my 2004 182 had the software version 8000.
I am probably completely wrong though. I'm sure someone will come along to help you shortly. :)
LB197
Id really take the top dash off, takes about half an hour the first time, roughly 10 screws, the previous owner may have put a steering control cable in with an after market stereo and not put the red plug back into the clock.
although some genuine stereos dont work across models - a scenic stereo apparently wont work in a clio even though some are identical
Thanks for your help guys looks like ill take the dash off and check cables. Failing that anyone want to buy a renault CD player lol :)
