hi all not doing this right away but was hoping that them who have done this could shed some light on the subject
firstly what gains are we looking at?
On standard internals and standard CR, low to mid 200s.
On standard internals but drop the CR (thicker gasket is simplest way) high 200s
After that the rods are not going to hack it.
			whats best to go for supercharger or turbo whats the difference between the pair
There isnt a single best answer.
Also superchargers fall into two very distinct categories:
Displacement type (ie the sort you see knocking around cheap off an old mini cooper etc)
Centrifugal type (essentially the same as the cold side of a turbo but driven by a gearbox not a turbine)
Biggest issues with displacement type chargers are that:
 they are bulky (mini one will not get much past 200bhp and even thats a tight fit in the bay)
they dont suit high revving high comp engines generally unless slightly oversized due to the way they will cavitate at high rpm (so to avoid you run a bigger charger and gear it down)
unless you can manage to install them with a clutch arrangement, they are sapping power the entire time, even when you are off boost which harms economy
Biggest issues with the centrifugal type chargers are:
They are expensive to buy
they generally cant be rebuilt, or are very expensive to have rebuilt
Turbochargers offer you much more flexibility as they can be bypassed by the wastegate when not required, and you can easily alter the power delivery without needing to change pulley sizes etc
The downside to turbochargers is they generate a lot of heat at the back of the bay
			whats involved what will i need
Depends which option you go for, but all will require:
 aftermarket management,
new pipework,
bigger injectors (megane are the easy option but TBH arent very good, Ive already lost a piston to a failed one and im not alone in that by any means!)
			and lastly what price roughly
Depends what power you are going for, its into the thousands not the hundred though, and very easy to do 10K or more!
