Is there a fuse for the volume control stalk?
The_Pirate
Car  Golf R
As above really? I cannot for the life of me fathom out why this wont work!? If there is a fuse is it any of these....?
Its a 172 Cup btw, cheers!
i doubt there is a fuse just for the stalk
i'd say fucked electronics inside stereo or fucked stalk it is french after all
Use your left hand to change the volume and move on with life? Have you checked its plugged into the back of the display correctly? Both plugs?
I expect it will be worn out mate - it only rubs against a piece of metal, like a heater resistor does - you can take it apart (only a few screws) and tighten it up, or buy another from another member - you can normally test it by pushing it hard in different directions to try to make it contact
I thought it was just the yellow one?
Whats worn out? The stalk or the head unit?
I've tried two others and they didn't work either, Russ?
Also, the radio won't pick up any other station other than Radio 1 aswell?
I'm sure Dave's selling an Alpine HU with iPod interface and remote control. The one out my 'berg Ph1.
