Bucket seat fitting list question
That's what I thought but if you look at this pic the subframe and seat bolts just don't line up so I'm missing something somewhere...
What are the black things on the bottom of the runner in the second pic? The thing with all the teeth on the inside? Mine didn't have that.
If you take that off and then drill holes through the subframe where the holes on the bottom of the runners are then just a nut and bolt should do it.
That's part of the slider, each notch is an adjustment point for the slider. Just drill through the subframe and bolt it to the runners, Job done.
