Phase 1 fog light air intake
Car  Clio 172 phase 1
Hi there any one on here make proper air intakes for these fogs ive used 2 80mm ducts off the bay but there just not that special i was wondering if any one actually made smoothed fiber glass ones... im going to have a smash at making my own but before i do i want to know if all goes wrong ive got a fall back lol
04092010618 by Ricard o1, on Flickr
Sony 018 by Ricard o1, on Flickr
Rubbish idea imo. Sucks in water in the winter and heat from the tarmac in the summer
Good point ... I know you kno you'r shizzle what would you run ? I've got the jms air box and enough pipe to make a ktec induction kit ... Also where would you take a cold air feed from? Standard?
On a phase 1 below the headlight.
you can cut the headlight support bracket in two so the filter has a line of sight to the little grill below the headlight. My old car made 180bhp on this setup with just a RS tuner map. Still had the cat and stock inlets.
Excellent :) I've got some time off the end of the week so going to have a bash at this then :) also going to have a go at ur guide to lowering the steering Column as my seats bolted to
to the floor pretty much... Some good work and good advice from you guys :) thanks
Mine is in the same place, works well.
I've got a Revotec self sealing take-off just on the 45 deg. bend for the ISCV rather than a small filter.
Tom something looks wrong with your top mount nuts, if they are a nut on the top of a tube sleeve then it should go under the the top mount (the bit in the engine bay)
Nothing wrong buddy, its just a different type of nut, I've got the bits under the tope mount that you have mentioned. Like this nut
