Scorpion RS192 exhaust db rating (with decat)?
Car  BG 182 FF
Has anyone tracked their RS192-equipped car or had it noise tested? Taking mine to Bedford on Friday evening but haven't had it tested yet and they have strict limits (101db static & 87.5 drive by). Does anyone know what it rates at? I've done quite a bit of searching but couldn't find anything conclusive. Thanks...
Thanks chaps, gives comfort... The advert said it had an RS192 but on my research travels it looks different to others? Here's a picture:
It says Scorpion on the tail pipes but it's locked away at the moment, I'll take another look later. Sounds good, whatever it is!
Decat must be horrid also, I'm doing it but for Lulz only, it's bad enough without it.
It's loud, but doesn't drone. Drove a 172 with ktec stealth and that cancelled out ALL other noise in the cabin! Got a feeling somethings blowing a little, it makes that slight puffing noise under the middle of the car when switching the engine off. Getting it checked in the morning...
Wondering if this is what's fitted to my car - http://www.scorpionexhaust.co.uk/scorpion-exhausts-half-system-renault-clio-182-03-06-2072-p.asp
I done a track day at Croft on Saturday just gone & it was only a 88db day, our 182 has the rs192 cat back system & cat in place & it was 82db static so you will be fine mate even with the decat as I took the scorpion decat off to be safe & it was hardly any louder with the decat on.
