**show us Your Engine Bay**
  Nimbus Grey 197
Mine has just got a update
Nice new top mounts and brace i think I'm going black inlet with blue cam cover and the black add on bits like engine mount
batesey
  172 Cup Turbo
Custom loom inside and out Batesey? Chucking the relay box makes it much cleaner.
Just a modified loom , standard ecu and fuse box is inside behind the dash mate, then the adaptronic ecu in glove box, scoff did it for me :) makes it so much cleaner
batesey
  172 Cup Turbo
I like it, then he re ran all the lights wires too?
Just extended the ecu wiring and fusebox wiring and ran it through the bulkhead, I re ran a few wires beforehand but nothing major, he re did the injector loom as it looks crap along the top as they come from the factory,
Thanks for the comments guys :) few bits I wana clean up though but I need the engine out to do so :)
Maybe over winter i'll do it all we'll see :)
  LY Megane R26
Finally managed to get some paint on the rocker cover, looks a lot tidier than before.
Before....
After......
Bit unsure if to do the back of the rocker cover, the raised bit in black or leave it as it is?
-J-
  RS2'ed 172 Cup
Before....
After......
Where did you get your Coil pack mount from? Had a look round your bay at FCS and the mount looks much better than the one I run with.
  Clio 172 Phase 2
Yea when I checked my brothers 182. He had about 3 mm of the catch holding the bonnet down. Lucky I saw it. Cleaned it all up. Grease etc. now works a gooden. U can normally tell by how loose the release catch is before u feel the friction of it opening the metal release
  RB Clio 182
ive just got it back from efi parts on Wednesday because i was having problems with the fueling, ive had a high pressure pump fitted and put the old ph1 fuel rail setup on and its running perfect now :)
I bet that shifts :)
How much did the whole conversion cost you?
  clio 182
yeh its quick, grips nice aswell in the dry but pointless in the wet, its just kept in the garage untill the suns out. ive lost count of the overall cost now but it wasnt cheap. probably £5000+ i bought a used kit for £1500 i think but buy the time i had the garrett uprated and rebuilt, then replaced and improved other bits its was probably over £3000 then installation and ecu was just over £2000. and now with the new fuel setup which cost more again. never new what it would all cost, just went for it ha, cant afford to do anything else for a wile :)
