I'd still spend the extra on the tapered Jenvey ones
What's the point on scrimping on a £2k throttle body setup?
Hmmm I see yeah. Would that fit within the filer housing though? Mine is literally pushing onto the bonnet as it is and have no space to push that further out.
You can put them between the trumpets and the backplate if you have enough space, and if you dont have then you cant fit 120mm trumpets anyway.
These are the spacers I have fitted justnow.
They fit inline with the trumpets. I originally bought them to fit behind a flat backing plate to give fuel rail clearance but then bought a deep backing plate so fitted them inside.
Because its been proven that tapered trumpets doesnt add anything and after that a bit of spun ally with a flared/rolled end is just that?
I agree with not scrimping but theres times when you get what you pay for and theres times where a bit of common sense can save you quite a bit of unnecessary expense.
We have found that the use of a taper that continues the shape of the ram pipe right through the throttle & manifold up to the valve, has improved torque through almost the entire power band.
The peak BHP that we have seen from the tapers with butterflies is better than we have achieved in similar tests using parallel bodies, barrel throttle bodies or a slide throttle assembly.
You say they don't add anything based on a test by the company that make the non tapered ones. Not based on the studies made by every other company.
We can all quote things off the internet but at the end of the day I'd rather have what Jenvey recommend for the Jenvey bodies - I'm sure they don't throw thousands into flow testing just to ignore the results.
They will be 48mm Morgan as they fit flush with my trumpets and body inlet.
It was a test by someone at that company on a single engine which led to them selling a product.
Let's just agree to disagree, I'm happy with my setup![]()
You buy yours direct mate?
These are the exact ones, right? Or do I still need to check any measurements, holes align etc? Sure you said they were 45mm standard?
http://www.jenvey.co.uk/home/access.../jenvey-dynamics/air-horn-48mm-x-120-ah48x120
What's the bore of them Neil, I have just had a cracking idea, hopefully it works. Will end up with 145m trumpet and the bodies themselves will be 65 mm further from the engine.
Anyone think that's too big? Chip? Going too big kill the BHP?
Im not throwing around quotes off of the internet though. Im going off of people who were there and saw the testing telling me it makes no real world difference. and the development of the adjustable ones came after seeing that tapered trumpets dont add anything - so i doubt its all made up to sell a product tbh
You mean you want 210mm plus the normal length of TB and inlet?
If so yes I think that will be too long and be likely to hurt top end power slightly, although will give awesome torque.
