White van revival
Car  Clio 182
My pal wants his van polished up.
i was thinking of using some iron x, bilt hamber clay, some kind of polish on my D/A with probably a white chemical guys pad followed by some wax to finish.
am I doing this in the right order and what polish should I use. I have Meg's 105 and 205 with different pads.
not looking for a full on correction, just a just buff and shine job.
Correct order but if you have some I'd go over the van with some tar remover before claying, possibly a sealant after the polish stage also.
So iron x doesn't remove the tar, cheers mate.
never used iron x before but I always de tar before clay or it gets messy.
the polish has me stumped on what to use.
I will be pointing him in the right direction regarding products so he doesn't use all mine, so feel free to make some alterations to my list.
I will however be doing it for him and I have a das6 pro to break the back of the work and all the other basic equiptment.
For a white van I'd be looking mor towards cleansing the paint and filling instead of a correcting polish.
Perhaps try tripple?
Wash it to get rid of the surface s**t
give it a liberal dose of TARdis/tar remover to remove tar and soften up the bugs
Douse it with iron x to dissolve the fall out
pressure wash it down then give it another wash to remove the last of the TARdis/iron x
clay it
cant help with polish as I've not used a da before
Optional step - give it a wipe down with AF Rejuvinate to get rid of the last of the stuff from the paintwork which will let the last stage protection bond to the paint better.
last stage protection with wax or sealant
My van after iron X.
Good effort Phase1sr
I have a black car which makes using Iron X a bit boring/difficult as you can't see it working, Same with Tardis :(
