Engine mount threaded
Hey guys,
Does anyone have any ideas on how to get this off.
Thanks.
Will it be safe to remove the jack from under the car and roll it forward with it like this?
I will be putting all of the bolts back in first.
DaveDreads
Yeah I have it out now I had to get it out of the mount and smack it with a hammer.
Is that engine mount dealer only or can I get one from the motor factors?
Ring Adam at Renault Wolverhampton, he's in the traders section,
he's got the best dealer prices around and delivers very quickly.
Also as long as the engine mount is bolted to the chassis and the cam belt bracket is bolted to the engine,
the rubber bump stops should stop the engine from moving too much if you need to roll it on and off the drive.
  182/RS2/ Turbo/Mk1
Yes that should be fine, just make sure it doesnt knock the master cylinder at the back if it comes down in the wrong place etc.
