What ways is there that i could boost the gaming performance om my computer system?
Top of the list should be GPU, for gaming SSD doesn't make that much difference. In terms of regular use of a PC an SSD makes a massive difference, once playing a game, not so much.
Gigabyte H61M-S2PV motherboard
Intel i3 Processor @ 3.30GHz
8GB Kingston HyperX blue RAM
1.5TB Seagate HDD
500GB Seagate HDD
Nvidia GT 640 Graphics Card.
It is only a year old. Cant afford the likes of a new graphics card or SSD. but Im going to see if i can get an i7 cheap in the new year when the sales are on.
That's why I said if you use your PC for other things besides gaming.![]()
I run an Extreme Edition first-gen i7. Personally I suggest that if you're going down the complete overhaul route, that a decent i5 would be far better suited.
D.
Any particular reason you don't like AMD? You can find the save location and put the saves onto a usb stick I suppose. Don't you use steam?
They don't offer the performance required for the development of C# applications.
Fair enough. What's your budget? That will make life easier and you can get some suggestions from others.
? what type of c# applications are you writing?! Obviously not standard applications? I use AMD in my pc without problems but I only develop asp.net and winforms at the moment.
SSD + GPU, your mobo won't be able to overclock much due to the chipset so not much point upgrading CPU without motherboard too.
Gpu - http://www.overclockers.co.uk/showproduct.php?prodid=GX-292-AS&groupid=701&catid=1914
SSD - http://www.overclockers.co.uk/showproduct.php?prodid=HD-041-IN&groupid=701&catid=2104
Total : £259.58
A little over budget, but that includes shipping and should last quite well.
Don't go for the MSI GPU's that look like this - http://www.overclockers.co.uk/showproduct.php?prodid=GX-205-MS&groupid=701&catid=1914 As they're noisy as hell and get on your tits very quickly IME.
Asp.net, winforms, web forms and ado.net at the moment but in the new year will be starting more advanced c# applications.
I dont know exactly how advanced the applications i will be creating will need to be in the new year
an AMD GPU isn't going to cause you any problems with any of the above. And if your looking to offload mathematical operations to the GPU, CUDAfy.NET works with Nvidia and AMD (CUDA and OpenCL).
He listed his mobo above, H61M-S2PV (no offence - it's a bad chipset). It's not worth adding an i7 without upgrading the mobo (and probably RAM required) too.
Oops I've missed that. Yep it's a basic board there's no point in using a i7 on that!
Yeah it will only be basic RAM that he has for a guess. Something like this will be a lot better! http://www.ebuyer.com/509513-corsair-8gb-ddr3-1600mhz-vengeance-kit-intel-haswell-cmy8gx3m2a1600c9b
I can't afford to upgrade most of my computer. A SSD and a new GPU will be fine at the moment. When I gwt more money available to my budget I will more than likely get a new mobo processor and ram. The current ram I have now was recommend by a fellow computing student.
That's what API's and HAL's are for mate. Don't limit your choice of GPU based on your programming language - unless it absolutely has to be nVidia specific. I can't think of many cases where it would need to be.I dont know exactly how advanced the applications i will be creating will need to be in the new year
