Clio Williams starter motor problems
DBS
  Clio Williams 2
So I have some intermittent starter motor problems with my Williams. I haven't manage to track down any situations where it does it regularly, it seems to be random.
I'm halfway through replacing the starter motor, and reading the instructions I noticed that the starter motor is supposed to have a heatshield. Mine definitely doesn't. Could that be the cause of the issue? Anyone know a good place to track down a heatshield?
Turns out replacing the starter is not an easy job! I'm 5 hours deep and still got some ridiculously hard to reach, rusted on bolts to shift.
16v_paddy
  Valvers & 172 Cup
They don't tend to survive not having a heatshield, here's the part number & what it looks like, you'll also need the 3 bolts for it, bottom right of the pic is the correct bolt
DBS
  Clio Williams 2
Am I on the right track by removing the exhaust manifold? The Williams manual doesn't mention it, but it's bang in the way.
16v_paddy
  Valvers & 172 Cup
There's no reason to have to take the manifold off 😳 but it certainly does make it incredibly easy to do the starter, some pics in this thread
There's only 3 bolts from the gearbox side and 1 nut attaching it to the bracket on the block - most people remove the bracket & bin it because it's a t**t & gets in the way
DaveL485
  21T, 9T, Meglio, V6
I fixed a few older cars starter issues like this by putting a relay in the circuit to the starter kick, so the key trips the relay and the relay activates the starter kick. Old wiring and old ignition switches. Might be worth a go before you pull the starter. Cost less than a tenner.
