Oops I did it again... Adey's Clio 200 EDC
  Clio RS 200
@Adey. I notice that you have the
Vgate Vlinker cable. I know from you video that is working as you manage to connect to the Renolink but It has the different chip and not the PIC18F25K80 recommended for that. I bought a cable but it doesn't work... Do you think the Vgate cable what you have will work with ddt4all and connect to the car without any problems as I do not have the Renault software?
  Clio RS 200
oh sweet, did you get RS monitor back on there?
Yes it was already there. Don't know what I did but the radio have all settings stored. I write them again in MFD but nothing... I did all again and nothing. Than I went to Audio settings Radio2012 and click the write there and it all come alive... But no sound 🤦‍♂️ check the settings again,hard reset, disconnect battery still no sound. The last thing I could try was disconnect the Powerbox 65.4 amp as I remember when I fitted that had same/similar issue and disconnecting it from the unit behind glovebox and connecting again did work so lock the car, went home for about 10min to get tools ,drink something and when I went back to the car start the engine to move car it started to work 😁 So all good in the end
