The Psychedelic Socialist's Focus ST
I have to say having a lightweight car makes such a difference to tyre and brake wear. I was wincing thinking of the cost of your M4 flying round @Nickw88
@The Psychedelic Socialist what pressure did you run on track?
Started at 2.1 cold then let them get up to 2.6/2.7 max.
Normally it's 2.4 cold so I reckon I might have damaged them going too hard before they'd increased in pressure much.
Yarp
  Clio 182, E46 M3
All I can say is the Conti sport contacts I had once wore quicker than my patience with the BMW.
I went through a set of front sport contact 7s in no time on the 5 series and M3. Turns out they like a bit more pressure or they roll onto the side walls a bit and wear mega fast on the outer edges. This set seem to be doing much better at 35psi compared to 32. I’ll have a better picture in another few thousand miles
Trainerbrow
  Mk1 Audi TT 3.2 V6
That's what chewed mine.
Nickw88
  BMW F82 M4
Tyres actually did pretty well! Now they’ve cleaned up they look fine. I still need to find my tool to measure them but doesn’t look they’ve used much at all surprisingly.
@The Psychedelic Socialist I’d definitely recommend the PS4S, i can now say I’ve tried them in the rain, snow, ice and on track. Not so great in the snow 😂
I’d like to think you’d get better distance than me and they’ll be cheaper too; around 10k rear/15k fronts and ~£1300 with alignment (265/30/20 / 285/30/20)
Brigsy
  T.Turbo
Handling wise, prob fuckall in it for slow day to day use on the top good brands michelin, conti etc.
Wear rate is something else though. I ran goodyears on the kangoo and the wear rate was ridiculous for road tyre/road use. The cup2's i replaced them with are wearing loads better in comparison 😅
I know a few people who ran contis and have went back to michelin as last longer.
Brigsy
  T.Turbo
I priced up a set of cup2 in 18s recently and the price has certainly shot up since i bought the last set. Worth the money though!
davo172
  TCR'd 172
There are PS S 5 now which replace the PS4S (dunno why they messed around with the naming of them 😖) to also consider.
Got these on 2 cars now after having
P ZEROS PS4 AND PS4'S .
PS5'S best of the lot imo get some you won't regret it.
Great looking tyres too.
Camskill usually aways cheapest just drop a drink to the local carefull tyre fitter.
Brigsy
  T.Turbo
Ps4s decent enough in winter, dont hook up as well on front in low temps but wont kill you. Same as any summer performace tyre in winter.
Crossclimates are a good summer/winter tyre but not performance.
Nickw88
  BMW F82 M4
Just a random one to throw in the hoop, but what about a set of Falken Azenis FK510 ?
I had a couple sets on my 430D, I actually really liked them and they held up well. Honestly can’t say I noticed much of difference when I had PS4S’s on straight afterwards. Got good mileage out of themand they were cheap!
ForceIndia
  Gentlemans spec 200
I use the fk520. They tend to do well in the German tests, which seem a bit more objective? And I spend 80% of the time on the motorway.
MLB
Not a direct comparison, but have them on my wife's Civic Type S (FWD, 140 bhp). Really like them for day to day driving. Don't think they'd hold up on a (mild) trackday though.
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
I didn't know they do PS5 S now or S5 however you want to call them until seeing this thread.
Just looked and they don't do them for the rears on my 3 series unfortunately.
I had PS4S on mine before they were killed off and have got PS5 on currently. I rate them though!
Nickw88
  BMW F82 M4
I would say this is better comparison than on my old 430D, although if they handled the weight and torque of that well enough I suspect the ST would be fine day to day also. You’re probably right about track, but then again if they’re cheap enough to replace and don’t ruin the fun too much that’s still not a bad place to be.
  • Like
Reactions: MLB
MLB
I was indeed thinking weight and power are probably more comparable with the 430d.
Another thing to consider, how many miles a year do you do @The Psychedelic Socialist? I don't do a lot of miles a year and usually replace tyres on age/cracking rather than actual wear. One of the reasons I'd probably go for the Continentals over the PS4S.
Not many to be honest. Probably <4,000/yr with most likely just the one track-day at CSF. Definitely don't need to be chasing the last couple of percent of performance but it'd be nice to have something that can handle a couple of track-days, last a couple of years and not fall off a cliff performance-wise when it gets cold / wet (at least compared to other tyres).
ForceIndia
  Gentlemans spec 200
<4k a year? Cup tyre for the summer, all seasons for the winter. They’ll last you 4yrs ffs.
Matt Cup
  Leon Cupra, 172 Cup
@The Psychedelic Socialist £100 cashback on Michelins atm. They periodically do this offer too, just keep your eyes peeled.
Doing the regular battery % check and charge and noticed a bunch of DTCs. Some relating to adapative headlight issues that I'll ask Ford to look at next time it's in with them (think it's a known issue with a software fix), but also spotted this one. Gave me a brief panic until I noticed the date and time....
Rojer
I had exactly the same on the ST last year 🤣
Had a new set of PS4Ss fitted today which was nice.
What wasn't nice was when the tyre guy showed me how bent the interior face of one of the wheels was. Interestingly it had been marked with a spot of paint so it clearly pre-dates my ownership. He showed me it on the balancing jig and it was properly all over the place but it's balanced up fine and I've never really felt a vibration (and that wheel was gone from front-left to rear-right).
EIther way probably a call to someone local with a hammer on Monday I guess...
Brigsy
  T.Turbo
With it balancing ok, wouldnt worry about it. Be fine on the back.
Deal with it if wheels ever need a refurb, or if a spare wheel comes up in better nick.
