Matthews Inferno Orange 182
Matthew_
Continuing on with more photos
Painted the front end to bring it back to orange. Some before photos
Progress & full painted using 2k white primer, colour matched spray paint from a company local to me & hycote clear lacquer
Matthew_
While working on the engine bay I was also working to fit the new to me exhaust (the cgr I have posted about on here previously). I wanted to do the job properly so I bought a new exhaust hanger mount kit from Pro - Am, a pair of gram exhaust mount bush's and a new OEM centre exhaust hanger.
Alot of the bolts were quite rusty holding the hanger mounts to the car but alot of wd-40 later they all came off. The hangers had previously been worked on by someone, they were standard but had been diy'd to look like a powerflex style bush but it wasn't great and once cut out came apart very easily. Very glad I replaced them for some proper bushes.
I cut out the majority of the bush material and then used a flat head and a hammer to remove the remains around the edges and then a file clean up the final bits. Having spent a decent amount of time cleaning them up I was happy with the finish and went to put the gram bushes in only to find out these weren't genuine hangers! And they wouldn't fit properly 🫣 so I had to start the whole thing again and I ordered 2 used genuine hangers off eBay.
Lesson learned always check parts if they are genuine! Especially on old cars like these. I hope I don't make this mistake again 😂
New hangers arrived a few days later and I set about cleaning them up. AGAIN 😬 this time it was easier and I'd learnt how to do it better. So I cut the main hanger out and then used a combination of the flat head, hammer and a wire wheel on a drill to clean them up and they were done much quicker.
Then I got to fitting the new bushes and test fitting them all onto the car which all went smoothly.
Knowing it all fitted, I put the new middle exhaust hanger on the car and set about tidying up the exhaust surrounds on the rear bumper. I took inspiration/copied Mr Underhill's idea of using the rubber edging and it worked perfectly and looks miles better than the old plastic that was on there as the old ones were white and wouldn't clean up but I've kept them to try and bring them back to life later down the line.
I then went to fit the new exhaust. This is where it goes down hill again 🙃 the new exhaust is missing part of the metal rod that would sit inside the hanger, it doesn't look to be cut off it looks to have been manufactured this way so the car it came off must have had a different hanger setup which I wasn't aware was a thing.
In the picture below the yellow line is what is missing
So after all this work to fit the new exhaust I ended up refitting the current ktec system to the car (in the rain which was not fun) and I now have another job on the list to manufacture and weld a new hanger to the back box and get the exhaust on the car.
But overall the exhaust sits much better and there is less rattle so it's a positive and I've cleaned the car up which is the never ending goal. (I don't have a photo of the finished result 🙃)
Matthew_
Just a small job completed the other day. Boot lock on the Clio started making a horrible grinding noise whenever youd go to lock the car, luckily it is a common issue with a plastic piece snapping inside the boot locking mechanism and I found loads of information on the forums (Thanks again to the forums, saved me many times!)
Before video
New part was ordered and is now fitted and means the boot now sounds normal again
Matthew_
Gave the Clio a good clean after work today, it's not been cleaned since before I started the engine bay work which was far too long. It's all ready for Autos De France at Oulton Park on Saturday
Since doing the work on the engine bay I have developed a very small misfire on idle. It's hard to tell from the sound of it but it is there and the car only recognises the fault when it sits idle for a few minutes, if you then drive off with the warning light flashing within a minute or so the light disappears, it's very odd. Ive checked spark plugs they look alright and we're all tight so my next guess is injectors. Need to get my code reader working again and then I'll see if I can investigate further before ordering some injectors. If anyone has any other suggestions that would be great.
Matt Cup
  Leon Cupra, 172 Cup
Alright fella. I think you were parked next to me this morning, sorry I didn’t stop to say hello before I shifted my car. Yours looked clean as hell btw 👍
