Petrol Blue 182 #1/29 - trying to remedy 6 years of neglect
Rys182
  Clio 182
I bought #1/29 of the petrol blue 182s from -Rob back in March 2018 after telling a friend I'd help him find a good 172 or 182 because he was keen. My first ever car was a 172 which I had from 2009 to 2013 or so, and had raved about them to my friends despite not having another RS since that 172. I had a mk2 Audi TT at the time, logged on to the forums here since I was a member many moons ago to check out cars for my mate, and saw the car for sale. Rather than pointing my mate at it, I bought it and sold him the TT instead.
Then it failed an MOT in mid 2019 which annoyed me no end because it was for silly stuff. A couple of days later I went out for a walk and trotted past my local VW garage where they had a lovely mk7.5 Golf R on the forecourt, so I popped in, had a test drive, and took delivery a few days later. The Clio sat outside for a few wet autumnal months after that, getting mouldy, before I garaged it early that winter to keep the mould off it. Bar a couple of feeble attempts to get it going again, it sat in the garage for the next 6 or so years until March this year.
I had to sell the Golf to help buy a house, and rather than buy a low-cost daily while I saved for something posh again, I decided it'd be cheaper to get the Clio going. Financially that's not paid off in the slightest since I'm now five grand deep into sorting it out :ROFLMAO:.
Starting from where it got to in -Rob's old thread before he sold it to me, the following happened in the year and a bit before the several years in the garage:
  • Belts and dephaser and full service
  • Rear pads, one new rear caliper
  • Front camber bolts
  • New injectors
  • Front ARB bushings
  • Set of new PS3s
  • Properly whacked the Cup splitter after a big compression at speed which broke it in two. Took that off
  • Misted up headlight covers (main part of the MOT failure, and I wanted to keep the black insert xenons, so I didn't want to just replace them with non-black ones)
  • Took the horn and cruise button plate thing off, after it caught fire a bit
Then while sat:
  • 3 very flat batteries as it sat in between pootling it out for a day or two every other year
  • One very dented bonnet after parking it back in the garage nose-in one day, but then the bonnet catch seized before the next attempt to work on it. Big dents trying to welly the bonnet to get the catch free
  • Paint scuffs as it became a thing to put cardboard boxes and other crap around and on top while in the garage
  • Lots of spiders made it their home
  • The dash mid plastic went incredibly gross
And here's what happened to get it where it is today:
  • New belts, dephaser pulley, water pump and aux belt
  • Oil service
  • Spark plugs
  • Front and rear OEM pads, one reconditioned front caliper
  • One front wheel bearing and both front ABS sensors
  • Both front CV boots and the main rack boot
  • UCH/ECU kit (lost a remap doing that I think, since it doesn't pop on the overrun any more)
  • Gearbox oil refresh
  • Refurbed all 4 Turinis
  • 4 new NS-2Rs
  • New Cup dampers and Gram springs all round and new top mounts
  • Took the PMS strut brace off
  • Powerflex front ARB bushings
  • New front track rods and inner rack arms
  • Full geo including weight setup
  • Titanium wheel bolts all around (they look sick) after one sheared off during the front suspension refresh
  • Bonnet dent removal
  • Big interior clean and exterior clean and polish, paint correction where possible (ongoing, will get a ceramic coat when that's all done)
  • Phase 1 horn stalk
As for what I still want to do:
I'd like to completely refresh the front brakes at some point, since they currently squeak a lot. To fix that (assuming some big stops from speed don't cure it) I probably need to take all the brake hardware off, clean it and regrease it, so while it's all off I could upgrade pads and discs, but then I could also fit spacers and a bigger brake kit. Does the wider track from the spacers make the handling worse for fast road use?
I've got some better condition silver seatbelts on the way since the mould knackered the current set, and I bought a Volantech horn and cruise button plate a couple of years ago but I'm in two minds whether I want to fit it or not. I like the look without it and I don't care about the cruise. No idea if that feature even works if I'm honest.
I've got a niggles list a mile long too. It rattles from basically everywhere (especially the driver's door window glass, and in the front dash somewhere), the ABS light comes on a good bit, the airbag light is on constantly from ~200 miles ago.
The ITG and Yozza are amazing if you ask me, but not if you ask my neighbours. I'll post some recent pics in separate posts.
Rys182
  Clio 182
A handful from the fallow years while it sat in the garage:
Rys182
  Clio 182
From the refresh
182Trev
  Clio RS182
Nice, cleans up well. I've just brought a non-cup 182 sport for a good price, mainly needs tiding, I get the parts list you state, mine has had a ton of work on it before I brought it, these are cheap French cars I suppose. Never seen a list of items need doing on a car in all my cars (although my Mini R56 JCW is close behind!).
182Trev
  Clio RS182
P.s. Love the wheels! Also any information on that steering wheel, my standard one is out of a bus ;)
Rys182
  Clio 182
It’s not too bad, just a shame it’s impossible to correct the worst bits of the paint. What I’ve had to do is probably not that far away from what I’d have had to do over the last 5 years anyway if it was up and running, I’ve just had to do it all at once.
The wheel is a variant of a pretty common Sabelt one that loads of Clio owners use, with the only special bit being the colour of the alcantara on the top. I’ve wrecked the colour and finish of that now I think, although apparently there are special brushes that you can very carefully use to bring it back to life. My detailer won’t touch it for fear of damaging it.
Fitting them is easy enough, you just need a wheel boss adaptor kit to bridge the stock rack to the new wheel. The stock wheel is awful imho because it’s so big, I much prefer a smaller wheel like the Sabelt one. Looks ace too.
Rys182
  Clio 182
The squeaky front passenger side brakes turned out to be a squeaky wheel bearing. I noticed it was only happening after the car had warmed up a bit and wasn’t affected by brake position, just wheel speed. Had it looked at today and my suspicion was right.
One fresh SNR bearing went on, and a new driveshaft bolt for good measure. Looking forward to some miles at the weekend now.
Rys182
  Clio 182
The squeaky front passenger side brakes turned out to not be a squeaky wheel bearing, and wasn't coming from the front either :ROFLMAO:
It came back on my next long-ish drive and it turns out it was affected by brake position, I just couldn't hear it properly from the driver's side. A friend drove it which let me have a proper listen and it was actually coming from the back, from a sticking caliper. Oh well, no harm in a fresh wheel bearing I guess.
I've got the hardware to replace the rear caliper (and disc, because that's a bit grim now, and pads) on that left rear, and I'll probably replace the disc and pads on the right side too at the same time since I could only buy the discs and pads as pairs. Hopefully this weekend for that.
I replaced the front top grill today with a brand new one (RPD are running out of those if anyone else needs a new one, and they won't be made any more I think) because the plastic had really faded. There was no need to get the bumper off for that, I just whacked the old grill a bit. Obviously one of the retaining clips fell to bits under the slightest force so I need to replace that.
I've also had a go at getting the rear wiper off to replace that with a delete blank, because the wiper is useless in the rain and I only drive it in the dry now anyway, but I absolutely mullered the wiper trying to undo the 13mm nut holding the motor to the boot. The wiper is now in the bin after the plastic near the mount shattered, and I've soaked the nut in WD40 to try and get it off again tomorrow.
I've also ordered body-coloured headlight washer blanks too, since those washers are similarly useless.
Rys182
  Clio 182
Since discovering the wonky rear caliper, things have escalated a bit. It got me wondering what other mechanical bits I could maybe also tend to this year before the weather gets manky over winter and one thing has led to another.
It started with commissioning a fully rebuilt gearbox to sort out the whining 5th gear, and has ended up with that box gaining a diff and strengthened rear casing. To go with that I’ve also got a new clutch and lightened flywheel, brand new uprated front brakes, and a new shifter.
The bad news is it’s taking ages for the gearbox to get finished and shipped to me, due to a wait on machining the rear casing, so it’s looking like mid October now to get it all put together.
While I’ve been waiting, the driver’s side window mechanism has decided to break. I’ll attempt fixing that myself, just waiting for a repair kit to arrive. Fingers crossed the motor is fine and it’s just the hardware that attaches everything and keeps it in place that’s gone.
Polynesian
  Alpina B3, 172, 325i
Good luck with your window mechanism…
How does the wiper delete at the back look now? All sorted and complete?
Rys182
  Clio 182
It looks really good, I’ll take a picture after the next proper clean this week.
Rys182
  Clio 182
Turns out the window regulator was completely knackered and had sheered the retaining brackets top and bottom, and the plastic through glass clip. I guess I could have figured that out from the mechanism poking out of the window frame when it went 😂
Fixed that today by replacing it with the “Hansun” one from ECP. The retaining bracket that goes through the window glass is different and you have to adapt the cables for power and control (comes with those) but otherwise it was straightforward.
Rys182
  Clio 182
Wiper delete looks alright. It’s just a piece of cut black acrylic, nothing fancy, but it looks inoffensive and does the job.
Rys182
  Clio 182
The gearbox finally arrived recently, so after a little wait for him to get back from holiday, it's in with Gary Spooner to get:
  • Fully reconditioned and cleaned up JC5-129 with Quaife QDF6M, rear case strengthening, and Evol rear mount
  • Sachs clutch with organic plate
  • Lightened flywheel
  • AP 300mm front brakes with DS2500 pads and new lines
  • One refurbished rear caliper to replace the sticky one, plus new Brembo pads for both sides, new lines
  • BTT body coloured headlight washer blanks
  • Pure shifter
Just in time to get garaged over the winter 🥲 Had the shifter in the footwell for the drive over to Gary earlier and it was gently rattling away. Subtle foreshadowing?
That's it for my "OEM+" upgrades this year. Next year I'll tackle front suspension upgrades and the subframes as the big spends on the mechanicals, along with some attention to the bodywork scuffs that I've accrued if I can find someone I trust to do a good job with the paint.
Rys182
  Clio 182
I’ve spent some time with it now following the upgrades, which all went well, but they’ve caused some secondary things to need to be addressed.
Firstly, the shifter rattle is ridiculous. I knew going into it that I’d need to spend some time modding it to fully rid it of rattle, per the many threads about it here on the forums, but I don’t understand why PMS aren’t motivated to fix it themselves. I don’t think it needs much either, just some lube/grease in the ball joint at the top of the tower.
The front brake kit needed some spacing for the Turinis to clear the new calipers. Gary picked 5mm but I’m probably going to replace those with 18mm Hubcentrics instead to get a bit more clearance. 5mm works but it’s the bare minimum.
Dropping the exhaust out to fit the shifter revealed the heatshields need replacing. One of the mounts is broken and rattles badly now ffs.
As for driving it, I really notice the lighter flywheel and the diff, which have made a big difference. Haven’t chucked it around too hard since the brakes need another bleed before they’re at max performance, and the geo is out. It’s booked in to get the geo sorted next week at NADUK.
It also had a clean the other day 😎
Polynesian
Looking good.
Do you have a plan for the exhaust heat shields? I need to source them too, wondering if there’s a cliosport solution or just a case of finding and refurbing old ones?
Rys182
  Clio 182
I don’t think there’s any alternative other than sourcing some from one being broken and refurbing them, and maybe wrapping too depending on taste/looks you want.
I also need to take the stock shifter surround out, looks a bit daft with it still on because you can’t see the carbon tower. Think it’s easy to do it, just a couple of clips and some Velcro, I’m just brimmed with lurgy and can barely get off the sofa. I know the dash plastics are awful, need to research what to do about those.
-Rob
I’m very happy to see this still around. Glad you’re putting in the money to upgrade and preserve it.
Let me know if you fancy selling it.
Rys182
  Clio 182
Felt so bad letting it sit fallow in the garage for so long that I’ve gone overboard to stave off the guilt. I’d need silly money, way more than it’s actually worth, or the missus would quite literally kill me 😂
MLB
Looking great as always!
I believe I've still got the set of 18mm front spacers with longer bolts that I've taken off mine recently if you're interested?
Rys182
  Clio 182
I’ve already ordered a set 😬
  • Haha
Reactions: MLB
