Titanium MrBlonde
Matt Cup
  Leon Cupra, 172 Cup
The bullets are now great mate,there the oe silver colour just aged.
But iam looking into decals but not sure on what colour
As my other post do them the same oe colour as the bullets. Not too stand out just nice and subtle.
clio_cup
  172 Cup
Personally i think the best looking wheels for a Clio 1*2
MrBlonde
So Speedline are no help with wheel decals and told me to look on ebay as there wheels are stamp printed and not stickers.
I have found an online company that can do them but not in a satin/matt black that i want,only in a gloss black.
Here are there choice of colours,i was thinking anthracite or a blue the same as speedline?
Louis
I Love Ed Sheeran
They definitely used to do them. I can try find my contact
MrBlonde
I know mate shame they dont
Hello Steve,
All Speedline wheels are all pad-printed, they are not decals.
All Speedline prints on the 2118 are Blue or White.
You may be able to find someone on eBay or similar who produce a copy decal/sticker?
Best Regards
Matthew Davies
SL Corse Ltd
Yarp
  182 Turbo, E46 M3
I’m team ducts. Fog lights are for sides and fogs nonces. You’re better than that.
MrBlonde
I Have been reading back through my build thread as i'am really considering selling the clio next year.I Didn't realise how much that i have done to the clio.So i have been just putting together a full sale advert with as much info as i can.So far i have just put a list of all the mods that have been done,im sure i have missed off a few little ones.
  • Wheel Stud Conversion
  • Phase one Stalk (for the horn)
  • Non Sport Non Sticky Dash trim parts,inside door handles,climate control
  • LED Phillips front side lights
  • Front chrome indicator bulbs
  • Rear LED number plate bulb
  • PMS Rear Shim spacers
  • 5mm Front Spacers
  • Cup headlight blanks (painted in the titanium silver)
  • Goodridge Front and Rear braided brake hoses
  • Pro-Am Roll centre kit
  • Pro-Am Bump steer
  • Black clock dial surround
  • NRG quick steering wheel release
  • Sparco Steering wheel
  • Remap by Engine Dynamics (Have print out)
  • Inner poly bushes
  • Outer Poly bushes
  • PBS Front brake pads (Prorace)
  • Front brake ducts
  • Cold air feed scoop and hose
  • Rear boot net
  • 172 Cup alternator set up (also powder coated)
  • Pair of Bimarco bucket seats
  • Jon foz seat mounts
  • PMS Shifter
  • Safety devices half roll cage
  • Motul RBF 600 brake fluid
  • Coilover covers
  • Front wishbone poly bush (black)
  • Small front number plate
  • Sunstrip
  • BC BR Coilovers (4.5kg F / 6KG Rear)
  • BC Solid top mounts
  • Blackline LSD
  • 8.5mm HT Leads
  • Steering wheel cover
  • Oil catch can
  • Ktec Sports cat
  • Custom non res exhaust centre section
  • Janspeed rear exhaust with custom slash cut tailpipes (2.25 dia bore system)
  • Speedline 2118 alloy wheels with fresh refurb
  • 4x Yoko AD08RS tyres (Pretty new)
  • Alpine headunit
  • Alpine speakers
Some maintenance list all done by Awmotorworks and myself for small jobs
  • Rebuilt front calipers
  • Refurb front hubs with new SNR bearings,Renault ABS sensors
  • Belts,water pump
  • New rear hard line brake pipe
  • New bump steer ends
  • New bearings in the RCK
  • New tie rods
  • Rebuilt Gearbox
  • New sump gasket
  • New rear main crankseal
  • New flywheel bolts
  • Engine oil and filter
  • Gearbox Oil
  • Wishbone,brackets,subframe brackets have been painted
I will put dates up on some parts that were done when i do an advert,bur gearbox etc was all done last year,i will have a look back again on bits as i have prob missed bits out.
MrBlonde
Been a while but,i will hopefully be starting to replace the rear beam i refurbished a while ago and treat all the underneath at the same time.
The process im thinking to do is..
•Remove rust with wire wheel/grinder etc and degrease
•Deox-c (on really rusty areas i cant get to with wire wheel)
•Hydrate 80
•Electeox
•Expoxy
•Dynax-UB or Dinitrol 4941
I will replace the heat shield with nimbus and also fit Pro Line braided PTFE axle lines
Please let me know of any other products which you recommend and also with the process.
A few photos of the rear beam and a photo of what i will do with the nimbus for the heat shield.
