Renault Clio 200
Jamie
Car  Audi B8.5 RS4 & 200
On 14 February 2026, I bought my Renault Clio 200. My 6 Clio (rookie by many people's standards).
This car is a small project for me, it's to keep miles and cost off my RS4.
I'm not the best with spanners, so some of this is a learning experience for me.
Car Details:
Number of owners 7 (including me)
Miles: 71k miles
Recaros & Speedline alloys & Cup Packs
Modifications:
  • Exhaust - unsure
  • Bilsetin coilovers and top mounts June 2023 - 63k miles
  • Remap at KTEC with 203BHP print out
Service History:
  • Registered April 2010
  • Service April 2011 – 12k miles
  • Service April 2013 – 16k miles
  • Service April 2016 – 38k miles
  • Service May 2018 – 42k miles
  • Service by KTEC 2019 50k miles - front and rear discs, steering arms, starter motor, track rods
  • Service August 2019 – 50k miles (Renault & Cambelt)
  • Service August 2020 – 51k miles
  • Service August 2021 – 53k miles
  • Service December 2022 – Cambelt, remap & O&F change (Next cambelt due December 2027)
  • Service January 2023 - 60k miles (new pads front and rear and O&F)
  • Service June 2023 (plugs, coils)
  • Parts February 2025 - 4 new tyres
New ownership (me):
  • Service Feb/March 2026 - 71k miles - oil and filter, spark plugs, coils, gearbox fluid
TASK 1:
On the way home, the front wipers stopped working. At this point, I was very irate and thankful it wasn't raining. The next day, after I had calmed, I removed the scuttle panel and found the wiper linkage had become detached. I reconnected, and hey presto, it's been fine since. While I was under the scuttle panel I expected to find a pool/puddle due to the drain holes, as this is very common. It was fine, and was in surprisingly good order (no pooling or scum).
One of the things I'd seen on the internet were people really struggling to remove the wiper arms. The night before I soaked in WD40 and the best tip/method to remove for me was to raise the wipers "vertically" and they come right off the thread - this was fine with me.
TASK 2:
When I picked up the car, I knew it needed a service. I could see from the history that it hadn't had much in a couple of years, albeit, this was only maximum 10k miles ago. The seller told me a home service was performed in October 2025 - I took this at face value (I don't think it had). In any regard, I got some ELF oil, new plugs, new coils - the air filter was recently replaced (that seemed truthful).
When under the car the engine/box sump had some oil (sigh) - this would be either a small leak (weep would best describe) or Stevie Wonder doing the oil change and not cleaning up after themselves. Best I could, I decontaminated the area with degreasant, emptying a whole spray can, wiping and sweeping. I think I got lucky here, because once a week I checked the sump area and it's all good, it remains nice and clean (except for the areas I couldn't properly clean).
TASK 3:
I didn't have a lot of time the following weekend, but I did get my polisher out and run it over the headlights - which although weren't that bad, it did bring them back to life.
TASK 4:
Rattles... The car is really low, and whilst messing about on the drive, I have caught the exhaust a couple of times, as annoyingly my drive is almost hump back shaped as you go 'up' the kerb and then 'down' to the drive - so it 'beaches' a little. Anyway, I had a rattle - I had a look under the car, the only thing I could see was the heat shield fouling the exhaust in areas. The shield is made of tin foil - so I just bent if marginally away from the exhaust - this almost entirely removed the rattle. I can see/hear a rattle from the rear diffuser on occasion (when hot) - so I assume there is a thin heat shield in there too, so I will take that down soon and have a look.
I cut off and replaced the old clamps, which were really rusty. A good pry with a pair of pliers and they came right off. I gummed up the join, as there was a slight blow; exhaust looks a bit s**t and quite boomy. The plan is to keep costs down, but, I may swap it out for a quieter/standard one.
When under there I did my best to look at the flexis - for peace of mine. Couldn't really see too much. For a meaningful investigation you'd need to remove the cross member and subframe. Not doing that at the moment.
When messing around with the exhaust, I can see the front discs are in bad shape. No idea how this didn't come up on the MoT (February 2026), Stevie strikes again. The next evening, I bought some c-hook discs and pads from Halo. I've also bought some brake pin punches and new pins - when it all arrives, I'll give it a go removing myself.
TASK 5:
Gear box fluid. I wanted to swap out the box fluid; thankfully the box seems in decent condition - not having crunches or any issues. The fluid change was pretty easy to do, but after 2 litres of ELF GL4 standard stuff, it wasn't dripping out the fill hole. I measured the outgoing oil using an old coke bottle and it was just under 2 litres - so I just left it at that. I swapped the old sump plug for a new OEM Renault one. I had a good look through the old fluid, and although very black, there didn't appear to be any filings or shavings.
For those wanting to do it themselves too, I found the fill plug to be a bit of a PITA to get to when only using axle stands, but thankfully who ever did it last, didn't over tighten it so easy to remove. I used a standard garden hose as the fill pipe with a funnel at one end. The standard garden hose was just a bit too big, so I trimmed the excess plastic and it fitted nicely in - snug. I jacked up the rear of the car too, so it was broadly flat, as the fluid is supposed to run out from the fill hole when sufficiently full. The internet suggests anywhere from 2 to 2.4 litres for a full fill. Given just under 2 litres came out, I was happy to put back in 2.
One of the things that has hit me immediately when initially driving the car, is that the gear change doesn't feel very positive. There doesn't feel like excessive rocking of the gearstick when you come on/off power, but you can feel the drive train inertia when you dump the clutch. Next on the agenda are new engine and gear box mounts. Some research and matching to my driving style suggests standard torque and engine mounts and upgraded gearbox upper and lower is the ticket. I'm going to give EVOL engineering upper and lower gearbox mounts a whirl, I'll do this after the brakes. I'll treat the standard engine upper and torque mounts as consumables. I had a look, and they seem easy to change. I'll just need to support the engine when doing the engine mount. I'll do both at the same time as removing the torque mount looks like it will give me a bit more room.
I will say, I drive quite sympathetically, but, it's obvious these gearboxes are proper dog s**t.
WHAT'S NEXT:
Items in the near term to be completed:
  • Front brake disc and pad change [waiting on items to be delivered].
  • Treat the subframe - when working on it so far the subframe is a bit rusty. When the manifold / cambelt needs changing, I'll replace for a new one [got some rust treatment and black metal paint to cover post rust treatment].
  • Spray centre caps black, to match wheels, currently grey.
  • New engine and gear box mounts [ordered one of four].
  • Machine polish (compound, polish, wax) - as soon as I get some time.
Coke bottle is old box fluid
Headlight pass with the polisher
Subframe to look into
Box fill wing nut. Bought from Amazon, likely right size, but very tight and made me nervous, so kept with the old one.
TASK 6
A little rushed, but I machine polished - cut, polish, wax and then sealed and put a cheap ceramic coat on (I appreciate this isn’t a real ceramic coat).
Time was against me, but I just wanted to get this out of the way, as the paint was fairly rough and unprotected. It could be better, but equally, a lot worse.
I largely skipped the wheels, as they will have to come off in the coming weeks so I can protect the arches and paint the centre caps. I did however give them a scrub.
TASK 7
Front discs, pads, and new brake fluid cap.
Watched a few videos and bought some tools to assist. I got some brake pin punches which made the job really easy. I also wd40 for a few days before, irritating with a tooth brush the bleed nipples and all 4 came off with no fuss.
I swapped the valves and installed new pins and spring locator/retainer.
The discs and spacers were rusted on and a bit of a pain to come off, but eventually relented.
Brake fluid reservoir still above min line, but I did lose some when swapping nipples and resetting the calipers.
The pads were also a bit of a pain to get out, even after resetting piston.
I made sure I decontaminated the area with brake cleaner and a rag.
After finishing I did get that ESP warning, but a google and lock to lock and it went away. Mild panic over.
Managed to drain the battery as I must have left the car on over night when in the garage.
Only driven a small distance but the improvement is profound.
Mintex c hook and discs.
Going to take it to a garage to bleed and flush the fluid - £50 and I know the nipples will be no fuss. I’d do it myself, but the fluid and kit to bleed will be more.
Final comment is I want a stud and nut conversion. What a pita to fit the wheels and spacers.
TASK 8
Sadly, not enough time to do them all, but today I did engine and torque mount and lower gearbox. I will do the upper gearbox mount in the next couple of weeks.
Only started the car, and there is more vibration, but not too much. The changes are preventative maintenance - box and manifold in mind.
I swapped out the engine mounts for new standard ones and the gearbox ones I’ve gone for evol. Evol lower gearbox mount was super cheap - £40, so gave it a go. Thus far, this is the only non standard mount so I know where vibration comes from, which albeit I’ve only faffed around on the drive, doesn’t seem to bad.
The torque mount and lower box were extremely easy to change. The main engine mount was a real pita though. People on the internet just say, support with Jack and unbolt. I don’t know if it was because I was on ramps and the angle was funny, but it took a lot of wiggling, jacking the engine up and down.
In the end, I bolted the mount to the car and loosely reinstalled the torque mount. This located the engine as it should be and then I wiggled and jacked and it got into place a lot more quickly.
Pictures of the new mounts - only 3 installed and the ones which came off - which didn’t seem that bad.
Left to do is the final gearbox mount, new brake fluid and bleed, and rear discs and pads. I was going to leave the rears, but, I figure I may as well just do them. I’ve still got one rust prevention and maintenance to do on the subframe. I’d also like a stud and nut conversion as I hated f**king around with the wheels with those massive spacers.
TASK 9
Finished off the final mount this afternoon - the upper gearbox mount. I watched a couple of videos and it wasn’t that bad, just quite fiddly, particularly the battery tray removal and reinstallation.
The upper engine mount took a bit of wiggling, this mount was the same, but a lot easier. I had a little pry bar and some trial and error with the jacking of the gearbox and soon it was off. The old mount wasn’t in that bad condition, to be honest.
Had a short drive shortly after, and this mount contributes nothing to additional vibration. The lower box mount gives off a lot of vibration but is settling (and reducing).
Overall, the gear changes are so much more positive and there is little play when coming on and off throttle, I’m very happy for £200 or so. Well worth it imo.
The gearbox mounts are from “Evol engineering”. The engine mounts were standard new units.
I’ve got some plastic paint to attempt painting the wheel caps tomorrow, as they are silver and I’m not keen against the back wheels. If I need to, I’ll have to get some new ones, in black, but at £140 for 4, I’d really rather not.
Another little gremlin has arisen, another common issue, but I’ve noticed the doors are dropping slightly, the drivers door catches on the metal latch. Fix seems straight forward, remove the door and just adjust/tighten.
New rear discs should be here next weekend, which will hopefully draw to a close mechanical maintenance until the next MOT in Feb 2027.
TASK 10
Rear discs and pads. I’ve also sprayed the centre caps black to match the wheels.
I had some trouble with the front wheel spacers, rears virtually fell off, someone actually used copper grease (on the rears).
No problem with any of the bolts, but I did find it challenging winding back the callipers. Both sides were tricky, but the rear left I thought was seized, it eventually relented when I was able to fashion a torque bar for it, for more leverage. The right hand side was stiff, but not to this level.
The callipers aren’t in the best state, some fresh paint or even a new set may be the way forward.
I bought a wheel fitting kit - long wheel bolt to align the spacer (below) - worth their weight in gold imo.
I had an issue a couple of weeks ago where I caught the front left door trim and it now catches by a mm or so on the door edge.
This was entirely my fault and so annoying. I have noticed a screw for the trim has come away during the said incident with the jack, so I am hoping a new one will push it back into place.
Worst case it’s a new one for about £100, just have to be patient for the right colour.
Wheel caps I am very pleased with. No immediate plans for anything more mechanical. I do want to deep clean the arches.
Thanks - this is all fairly new to me. I used to tinker on the Williams 20 years ago, but nothing for a substantial period. It’s a lot easier now with YouTube guides. I’m also less cheap and have invested in some new tools to aid here and there.
The issue with these cars, is that you can tell they’re 16 years old; crusty. I’m looking forward to deep cleaning the arch area. I also want to rust treat the radiator support frame as that’s pretty rotten.
On the MOT was an advisory for the steering column. I saw that frequently myself when looking at 200s. I haven’t felt any excessive play myself, but I may look to sort that out at some point in the next 12 months too.
I’d like to get the dash strips in yellow. Yellow seat belts are also on the list, but, not sure how tricky and how much interior has to come out to replace.
You'll probably have to remove the rear panel to get the seat belt reel out. What was the advisory for the steering column? Mine said play in the column which tured out to be the universal joint but tightening it made the bloody thing creak worse than my knees do 😂.
TASK 11
Fiddled with the side skirts, as I have loose fitting clips at both rears.
One clip has evidently snapped (I can see it), went a bit cheap for now, and aided stick with some 3M tape.
I also reattached the trim where I caught it on the jack, and tried to push it back into place. The passenger door no longer catches - hopefully a permanent fix, tbc.
A secondary pic of the RS4, where someone has really dented the door, really irritated about that, as it’s massive.
Pics of the sill line show the door being an inconsistent distance. You can see the hairline cracks in the sill where I bent it from the underside. Hardly noticeable, but frustratingly, I know it’s there
TASK 12
Flushed the brake fluid, fitted braided brake lines front and rear and bled the braking system. I did pay someone to do this, as I didn't have a bleed kit, but I should have just bought a kit myself, as it was £200 all in. They did quote me £50+VAT for the brake fluid and an hour of labour £80+VAT to fit the brake lines, but due to some corrosion it took longer and as a consequence cost me more. Anyway, it's done now and not something I need to worry about, for a while. Brakes feel really good. Front c hooks and mintex pads, and rear are cross drilled with mintex pads.
OTHER ADMIN
I was having a misfire which I isolated to the coils. I bought some Hela ignition coils and on installation noticed a cold start issue, so I swapped back to the old OEM ones. I took the Hela ones back to GSF and went with some Bosch items, and it's running beautifully again - no cold start/running issues.
The passenger door is all good; not catching on the sill, which is helpful.
Some more unnecessary spending.
I searched quite a few plates and ended up with this one. Most of the “cheap” good ones had gone. All in, including plates and insurance it was about £300.
NBS is (for me at least), short for nimbus. Having hung it, I can’t see past Clio No BS.
I’m late to the CL10 plate party, loads of the good ones had gone. I loved my Trophy plate, it was on number 67. Subsequently written off and the plate lives on, on another car.
I loved the Trophy, I sold it for a Megane R26, which I didn’t much enjoy and sold the Megane about a year later.
Task 13
After getting the car back from having the brake fluid flush, I got a transmission fluid smell / clutch burn at high rpm. Urgh.
They had overfilled the reservoir by 50mil, so I syringed that out and bled the clutch - only needed to remove the cold air feed. Since that, all good. No smell and the car feels great at the moment. I assume they somehow managed to get some airlock.
It only takes 10 mins, a bit of admin well worth it. Got my 10 year old to do the clutch.
Task 14
I was prepping the car for a brief wash last Friday and I noticed a scored groove around the drivers disk - it was entirely symmetrical which led me to believe something may have been stuck in the calliper.
With the collection of tools acquired (namely brake pins and the alloy wheel long bolts, very helpful when you have massive spacers) and the recent nature of disc and pads changes, I was able to remove the brake pins and pads within a couple of minutes.
I sent off the pics to Halo brakes, as that's where I got the discs and their opinion was foreign object too. The chap at Halo was very helpful when we spoke, they do in house testing before dispatching discs, checking each set with a micrometer which gave him comfort it would be very unlikely disc thickness.
When I mildly brake from higher speeds there is a small amount of steering wheel feedback; if I brake moderately to hard, there isn't any, so the pad must still be mildly misshaped which is removed with firmer braking - hopefully more miles and it'll scrub out.
I went to Manchester and back this week, I spotted a couple of cool cars on the road. What surprised me, was the amount of attention the Clio got. I got 3 thumbs up, 1 from some dude in a Ferrari, and a couple of BMW drivers. A few weeks ago some guy in a Porsche also gave me a nod - that was a Cayman.
I've also had a lot of comments and gestures toward the plate - which is cool. A lot of people drove past and were pointing at it.
On the recent motorway trips I've also managed 37mpg, which is better than I anticipated, due to their reputation. That was at a pretty constant 70mph on the speedo.
I've got Simply French next week, so I am going to try and give it a good clean this week.
Ahead of simply French next week, I gave it a polish and debadged the rear, in anticipation of my new RS badges turning up, but I really like it bare.
Still got a decent mirror shine on it, but I think I’ll need to invest in some “proper” ceramic coating as the cheapo autoglym/meguiars (the two I have), seem to last only a short period of time.
