MAXRUNDOWN
Have you had a mapp gas torch or induction heater on it too?
Cumpact is still available
Did you put the impact gun on the puller? Sometimes that shocks them.
Also of you do the bolt up on the puller f**k tight then smash the end of the bolt with a club hammer... repeat many times... that can also work.
Can I buy it and strip it for parts?Cumpact is still available
I've had to use a sledge hammer before, they can be right dicks.
Only if its super cheap and there are loads of other people who want to buy it to use mate.Can I buy it and strip it for parts?
So you twatted your plinky with a hammer?
Hammer won.
We’ve all been there pal.Yup 🤣
Rub it back, bit of hammerite, job done.
Impressed with the amount of work you are doing on this Rojer. Did you get braided brake hoses to replace the originals?
If it drove well before its going to be superb after!
