MAXRUNDOWN
Have you had a mapp gas torch or induction heater on it too?
Cumpact is still available
Did you put the impact gun on the puller? Sometimes that shocks them.
Also of you do the bolt up on the puller f**k tight then smash the end of the bolt with a club hammer... repeat many times... that can also work.
Can I buy it and strip it for parts?Cumpact is still available
I've had to use a sledge hammer before, they can be right dicks.
Only if its super cheap and there are loads of other people who want to buy it to use mate.Can I buy it and strip it for parts?
We’ve all been there pal.
Rub it back, bit of hammerite, job done.
Impressed with the amount of work you are doing on this Rojer. Did you get braided brake hoses to replace the originals?
If it drove well before its going to be superb after!
Is that a crack? My silicone hose that I got to replace the old knackered oem one that sits in that clip oozes oil. It’s very annoying.After my drive yesterday I thought I would have a check under the bonnet and sure enough looks like I have a leak. Explains why it was so dirty before. I better order a rocker cover gasket.
Mine had a pinhole where it rubbed on that clip.Hmm, tbh I just jumped straight to the rocker cover gasket. I will have to inspect the pipe and see, but it seemed dry when I moved it earlier.
How much was that if you don’t mind me asking?Ordered a replacement silicone pipe as per @Sash suggestion so just waiting for that to arrive. Also got a cracking deal on an OE Valeo condenser and drier which has arrived. It would be nice for one of the cars to have working AC.
