Rojer's 200T
Touring_Rob
Did you put the impact gun on the puller? Sometimes that shocks them.
Also if you do the bolt up on the puller f**k tight then smash the end of the bolt with a club hammer... repeat many times... that can also work.
Rojer
Day 3 of fighting the driveshaft. My hydraulic press came and it did nothing. Went back to the original tool and managed to get it to pop. After a bit more fighting it's out.
I had to sacrifice some of the threads on the joint. I take it that it's not worth repairing the threads and just buying a new joint? Given the state of the old one, it's probably no bad thing.
Rojer
Can anyone tell me if SNR OJK55.005 is the right joint? I can't find the Renault part number on Partsouq.
Rojer
Another hour or so this evening dodging the rain. I desperately wanted to clean around the rocker cover as it was caked with oil and grime everywhere. Stripped it back a little for better access to give it a good scrub. Its not perfect, but the rocker area looks a million times better.
Whilst I was there I replaced the turbo gasket seal and torqued to 22NM as per manual. Someone had previously tried to silicone the old one. Found a bolt for the hot side pipe that was also missing and had a general tidy up.
Got the old crappy broken badge off and replaced it with a new one. Looks a million times better.
Spent the last bit of time cleaning up some of the CV grease and grime that had gone everywhere. Looks like its going to rain the rest of the week so I will have to wait until the weekend to carry on.
Just for @YorkshireKyle
Rojer
I have never known the weather to be so temperamental. It's been sunshine and then thunder and sunshine again all day. Managed to get a little bit of time between showers.
Scuttle off and the drivers side drain was blocked. Grabbed a pipe cleaner and unblocked it.
Got the brakes, shock, hub and arch liners out.
Lots of crap in the arch
Quick blast with APC, a brush and the hose and it looks a lot better.
I have booked Monday off so over a long weekend I'm hoping to get it all back together with all the new bits.
Rojer
So yesterday started well....
Very lucky i didn't break it or need to go to a+e to put a needle through the nail to release all the blood.
After speaking to @Brigsy this morning about the CV joint, I was worried i would have to take the shaft out to get proper purchase on it. I had my first bit of luck and after a couple of taps it came off.
Gave the hub a quick going over with some Hammerite. Anyone who is observant, might know there is something wrong in this photo.
Everything was pretty tired.
Sanded the worst of the corrosion off the spring and touched it up with Hammerite, also fitted some new spring protector sleeve as the old ones had perished.
Annoyingly im still waiting on my CV joint from Kam as it had to come from Germany so its back together as much as it can be.
When tightening up the pinch bolt, it ended up snapping. It's only then i realised someone had used non genuine nuts and bolts. The other side bolt was actually bent. Means more annoying delays whilst I wait for parts. Tomorrow it will be the rears turn.
Rojer
Rear shocks done, had an absolute battle getting the bolts out. After a couple of hours fighting, they came free. Just like the fronts, everything is well past it. I did attempt to free up the handbrake, but it would never return properly so a job for another day. Might just replace the caliper.
Just waiting for the final parts so I can finish putting it back together and get an alignment.
