Trophy, Audi TT,
				There are quite a few references on here to creaky clutches, I.E. you get a creak when you press the pedal.  Mine has suffered this since I bought it so a couple of weeks ago I decided to look into it.
I lubricated the cable where it comes through the bulkhead, under the dash, but this made no difference. With someone working the pedal I could actually hear the creak it in the clutch area so I turned my attention there.
I removed the air box so I could get to the clutch lever easily. With this removed I disconnected the clutch cable for a moment and then removed the rubber lever gaiter. I could then see the ball where the lever pivots. I gave this a squirt of grease.
I then reconnected the clutch cable (still with the gaiter off) and tried the clutch again. It was slightly smother but the creak was still there, louder in fact as with the gaiter removed you could hear it more.
The noise seemed to be coming from the clutch diaphragm fingers… I popped to the motor factors and bought a tin of spray grease for £3.50, one with a long spray extension on. Back home I made the extension longer with a pen refill (I blew the ink out first!)
With the engine on tick over, and a good torch so I could see where I was squirting, I gave the clutch diaphragm fingers a squirt of grease … I didn’t use much for obvious reasons! I got in the car and worked the clutch… not only had the creak gone but the clutch was noticeably lighter and much smother! It REALLY has made a massive difference to how the clutch feels!
I know some people are going to say that you should not get grease near a clutch but in reality I was spraying it well away from any friction material. Anyway, soon as you get some revs on there the excess will centrifuge off to the bell housing. just go easy with the grease!
Up to you if you try it… As I say it’s worked for me and my clutch is creak free and nice and smooth!
