£300.00 on brakes!!
Car  RenaultSport clio 172 mk2
Just spent £300.00 on my brakes, ive bought
1) 4 X Goodridge Braided Brake Lines
2) Castrol Super DOT 4 Brake Fluid
3) 2 X NEW Front Renault Discs (Mine are about worn)
4) 2 X NEW Front Ferrodo DS2500 Brake Pads
5) 2 X NEW Rear EBC Kevlar Pads
and finally ive bought some 172 cup springs, having it all fitted by a friend for next to nothing, so hopefully the brakes should be s***hot.:D
Should have uprated them with better discs. Probably about the same or cheaper than OE stuff
WOW thats expensive...
The above kit is 185 + rear pads+fluid at www.Yozzasport.com
BYW its a good set-up you will be impressed..!
Nah wasnt that expensive, the £300 odd price includes the price of the cup springs which cost me £50.00
total cost was
brake lines £50
rear pads £40
Front pads £80
Renault Discs £60
Brake fluid £10
So total on brakes was about £240.00 maximum.
Bought the Discs From GSF car parts
what make and part code are the OE pads? need front and rears soon! and would like the best price, naturally ;)
I got the rear kevlars from k-tec and the front ferrodos from yozzasport
Fred2001Dynamic said:
nope std are made by valeo or bendix
but the ones from gsf are brembo, so technically there not standard renault ones then is that what your saying?
Ferodo DS2500 Brake Pads "race use only" Are these going to be any use for normal everyday driving??
rob172cup said:
so if i rang up gsf and asked for std disks they would give me brembo ones
Well ive already bought some and on the website they are shown as 280mm vented renault front discs, so while they are standard discs, they are perhaps made by brembo instead, i personally dont care as long as they look standard and work properly.
they are NOT race use only they are fast road use/race use! the ds3000 are race use only
the brembos are OE replacements, identical
GSF stock BENDIX and BREMBO, but they generally send whatever!!!
total cost was
brake lines £50
rear pads £40
Front pads £80
Renault Discs £60
Brake fluid £10
no mention of springs.......................
read the first post, the one you replied too, where it clearly states i also bought some..... see it, :rasp:
mind my english m8s...I'm a spanish lad...dunno what does OE and OR mean...
by the way, why not ferodos 2500 at the back??
what you picked bites more or less than the ferodos?will they long at least as the ferodos?
thanks, cheers
OE = Original Equipment, Manufactuers standard parts
no need to upgrade the rear
DS2500's are a brilliant pad
thks fred, but which are the main differences between the rear pads which he picked up and the rear 2500?
and what's OR?
thks again
