Taken from an E-mail I recieved from Nick.
If it wasent for the fact Ill be soon selling my car I would buy this kit.
Hill Power
Renault Clio 1.2 16v Induction Kit
The induction kit we have designed for the 1.2 16v has been made with cold air induction in mind.
Starting with the filter we use a RAMAIR foam filter and have relocated the induction to the front of the engine bay and housed it inside on of our heat protective shields. These are made with spun aluminium end caps and a heat shield material to keep the filter inside cold (look down the back of your engine and you will see Renault use it for protecting delicate parts from exhaust heat), the colder the air going into your engine the more power it can produce. The housing has an aperture along it’s whole length to allow cold air to be feed to the filter from the front of the car, having an open housing also lets you hear the induction roar, unobtrusive at cruising but joyous on acceleration and with the blanking plate to the side of the radiator removed this allows a feed of cold air from the front of the vehicle to be directed at the filter and housing. Moving towards the engine we use polished aluminium and silicone pipe (available in blue, yellow, red or black) going to the O/E filter replacement plate, which is bolted in place of the original air box. Because of the placement of the filter and housing the induction kit is not suitable for climate control vehicles.
The kit improves initial and part throttle response and adds approx 5 to 8bhp to the peak max power.
Kit part number IND03
Retail price £130.00 plus vat
Fitted retail price £145.00 plus vat
To complement the induction kit.
During development we found that with the induction kit fitted the engine was running leaner above 3000rpm, we addressed this by fitting an Uprated fuel pressure regulator which not only took fuelling to a safer level also gave an added improvement on acceleration and power.
Because of the nature and placement of the unit we would recommend that you take advantage of our fitting service or have a skilled technician fit it for you.
Regulator part number UR03 Retail price fitted £90.00 plus vat
