1.2 16v not starting
Car  E46 M3
The 1.2 run around has died. Parked up nothing unusual then the next day refuses to start.
Has spark and fuel to the rail. Fires on easy start which points to injectors. Tried a spare ecu (cheers Mick) with no change so I changed the top engine loom but it's still not going.
Unsure where to go next.
Check the injectors and wiring are working correctly, put each one in a bottle and observe when turning over. It'll be a fuel issue no doubt as it's firing on easy start
Already done that and theres nothing out of any of them. I've changed the loom so the wiring should be fine and I've tried a different ECU. Is there anything that can be telling the ECU not to open the injectors?
