1.2 16v oil filter
Martin_172
went in to get an oil filter to do an oil change especially after yesterdays hard driving at the stirling meet and the filter i got instead of being a cylidner can was just a paper like filter, like a mini cylinder airfilter, does this sound right for the 1.2 16v engine? 02 plate btw
cheers
Martin_172
  ST
Its an oil filter....but not for a clio mate...
Just go to renault n get one from them IIRC the filter and sump plug washer is about £6 in total.
Al.
  Monaco Blue Mk2
What the fluck! lol.
As said best just going to Renault for a filter and washer, just give them your reg and they'll sort you out, about 6 quid as mentioned.
If you don't change the 10p washer it'll leak.
  CB600FS
Some 1.2 16V's have that oil filter though....
Stick your hand down the back of the engine (O/S) and its going upwards, should be able to feel if its a metal one or plastic outer - in which case it is the paper element.
Or even easier take the wheel off, see it straight ahead of you
  Lionel Richie
no thats correct, it sits inside a plastic hosing under the drivers side front wheel arch (same as mine)
there are 3 different filters available for that engine
  Lionel Richie
its thanks to the 20year old design of the engine (originally from the twingo) D7F
its the only engine in the renault range to have such a MASSIVE (over 100 pages) fault finding section in the dearlership handbook
Its built to a cost not a spec what do you expect get a diesel.
ha, i'll leave the diseasel's to you!
(i'm buying a 106 oil burner btw;))
Seen the light have we?
Will we be seeing the Yozzasport tunning kits soon I cannot wait for the PF97 reviews.
