1.2 subframe on a 172...and steering problems
  01 Clio 172 PH1
i searched already but couldn't find results to my questions...anyways....
are the missing lower gearbox mount holes marked on the 1.2 subframe?
how hard is it to drill through? is it doable with the subframe on the car?
i don't really want to take off the subframe in my car park on jackstands.....so if i can just drill the holes with the car jacked it'd be a lot easier
reason... i asked my mechanic to replace the subframe after seeing the wishbone mount poorly welded on for reasons unknown...he put a subframe on and left the lower gearbox mount out without telling me.... went to another specialist and noticed the missing mount so i want to sort this
also have some issues with steering that comes and goes...sometimes my wheel is a bit to the left when driving straight, sometimes its to the right...
also i sometimes get knocks when i turn the wheel without car moving.. i bought some new cup wishbones and waiting to see if it will solve the issue but its not, should i be looking at a new rack?
two mechanics confirmed there is no movement on the inner and outer tie rods... one said rack, one said ball joints...
  01 Clio 172 PH1
cause im pissed and very close to burning to car
problem after problem....
anyways the main reason is... i dont really want to.take the subframe off unless i have to
and since the subframe doesnt fit in the car...i need to pay someone to pick it up for me
  Listerine & Poledo
Ah yes, sorry, being dim. You've already got the frame in place and etc.
Hmmmm, Well, if you can rig it without pulling the car apart, superb, but be ready for excess swearing
  01 Clio 172 PH1
lol ive been swearing a lot doing the upper tranny mount already which.... is still not done by the way
  01 Clio 172 PH1
not sure mate....like everything else on the car...its airgunned in by my mechanic....it should be tight but...i will look at it next time when i get my digital torque wrench adapter
i had a look under the car...it seems the subframe isnt too hard to take off but...i will need the car jacked up quite a bit and...its gonna be a pain in the ass to do it by myself....
  01 Clio 172 PH1
thanks a lot dan! ok i will try and find a proper subframe then....
hope i dont get crushed by the subframe when it falls on me lol
  01 Clio 172 PH1
dan ..got another q, will a 172 cup subframe fit a 172 as the wishbone mounting points are wider? since im getting looking for another subframe it would make sense to upgrade
green
  Hi comp phase 1
I'm pretty sure the cup subframe will fit. I think it would need the cup anti roll bar too
  01 Clio 172 PH1
are the arb droplinks different or the arb itself? my searches only turn up how hard it is to install the arb bushes and i don't think im competent enough to do it
green
  Hi comp phase 1
The cup ARB is thicker..25mm and the spacing of the drop links are different too
